Clutch problems
Old Jul 9, 2008 | 06:19 PM
Mador's Avatar
Default Clutch problems
Hello im from New Zealand,
Own a 1996 Integra Type R JDM Spec,
Blew my standard clutch and just finished bolting up a new 4 Puk clutch with Heavy Duty pressure plate and lightened flywheel,
Put everything back together but there is a soft clutch pedal and will not go into gear, the Clutch fork is moving but not very far, i have put in new clutch fluid Super Dot 4 and I have bled it correctly with a clear pipe into a bottle, but still Bugger all feeling in the clutch and all...
Anyone able to help me out here?
Greatly appreciated,
Ben.
Old Jul 9, 2008 | 10:59 PM
inspyral's Avatar
What procedure did you use to bleed the system? Did you close the bleeder valve at the bottom of the clutch pedal's stroke before lifting the pedal back up?
Old Jul 10, 2008 | 02:18 AM
Mador's Avatar
Default Re: (inspyral)
Got a bleeder kit for brakes, comes with clear tube and bottle, pumped it, held down opened closed and repeated, strangely, after leaving the car and coming back after an hour or 2 I put my foot on the clutch and theres alot of pressure, but it wasnt happy when trying to go into gear, started the car in gear with foot on the clutch and it was turning over and not moving, battery died so it didnt start
Mador
Jul 10, 2008 09:09 AM
mikeycivic
Jun 4, 2007 05:32 PM
hellrsnCL
Aug 10, 2005 08:29 AM
FK00GSR
Mar 31, 2005 06:55 AM
