clutch lost all pressure, is it broken?
today i checked my clutch fluid and it was down a bit so i added some and figured i would bleed the line. I put a hose on the nipple and put in in fluid then pumped the clutch and opened it and repeated.
Then while i was pumping it back up the third time it was squeaking like metal was rubbing and when i opened and closed the valve the clutch no longer had any pressure.
Before the clutch felt like it was spring loaded. I didnt have to pull it back off the bottom even after i opened the valve and let out the pressure.
Now the clutch is bottomed out and when i pull it back up it just falls back to the floor
please help me.
please help me.
you may have air pockets in the lines still.
If problem still persists, it the master cylinder.
redline7
Feb 23, 2008 08:53 PM
