CLUTCH HELP
Detailed explaination: http://integra.vtec.net/driving/dclutch.html
Short explaination: It is used for when you want to go from 5th to 3rd. You may notice that if you go straight from 5th to 3rd, it is a little hard getting it in sometimes. Double clutching is when you first take it out of 5th, let off the clutch, then rev up the engine to about where it should be for 3rd gear, push the clutch in, put it in 3rd, let the clutch out.
Also, just a FYI, lay off the caps a little.
hassan21
10
May 17, 2008 11:43 PM
