clutch bleed mystery
Old Sep 25, 2005 | 09:25 AM
timsch75's Avatar
Default clutch bleed mystery
I bled my clutch today following the Honda service manual instructions that said to run a line from the slave cylinder bleed valve to a container with brake fluid in it and pump the clutch until no air came out of the valve. I failed to keep the reservoir full and got air in the line. To get this air out, I ran at least a pint of fluid through the system, until no air came out. I had my buddy pump the pedal a few times with the bleed valve closed to check the resistance and he said it felt OK. I bled it one more time and a fair amount of air came out, so we bled it a few more times. Each time he would pump with the bleeder closed and I would bleed it afterward, we would get some air. What is going on here?
Bleeding according to the book, the fluid coming out has no air. How can operating the clutch create bubbles that can be bled out?
Old Sep 25, 2005 | 03:23 PM
SAVIOVEGA's Avatar
Default Re: clutch bleed mystery (timsch75)
When you open the bleeder valve, is the pedal being held down ?
Old Sep 26, 2005 | 05:40 AM
timsch75's Avatar
no. the pedal is pumped several times w/ valve closed. pedal is then pumped several times w/ valve open. the first couple of pumps w/ valve open yield bubbles in the fluid each time.
Old Sep 26, 2005 | 01:06 PM
.water's Avatar
Default Re: (timsch75)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timsch75 &raquo;</TD></TR><TR><TD CLASS="quote">no. the pedal is pumped several times w/ valve closed. pedal is then pumped several times w/ valve open. the first couple of pumps w/ valve open yield bubbles in the fluid each time.
huh? lol
push down and crack valve(keep pushing down), close valve off dedal. again again until no air, since you put air in the line alot you have to do like 20times?? lol
Old Sep 26, 2005 | 01:28 PM
SAVIOVEGA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timsch75 &raquo;</TD></TR><TR><TD CLASS="quote">no. the pedal is pumped several times w/ valve closed. pedal is then pumped several times w/ valve open. the first couple of pumps w/ valve open yield bubbles in the fluid each time.</TD></TR></TABLE>
No. First your friend has to pump the pedal a couple of times. Then as he holds down the pedal, you open the bleeder valve to let air/fluid out. Then close the valve. Then start pumping again. Repeat this process until there is no more air in the lines
Anytime the valve is open the pedal should be held down. If you pump with the pedal with the valve open, it will suck in air.
Old Sep 27, 2005 | 07:46 AM
JimBlake's Avatar
Default Re: (SAVIOVEGA)
Another suggestion...
After you've opened the valve & bled off the fluid, there's nothing pushing the pedal back up. You gotta lift the pedal, but don't let it snap suddenly upwards. That seems to make it more likely to suck air into the MC. Push the pedal upwards & control it so it moves smoothly.
TravisCadello
Oct 29, 2008 07:12 AM
r1de4life
Jun 12, 2006 11:23 AM
r1de4life
Jan 16, 2006 10:06 AM
1SlowSi
Aug 16, 2005 07:24 AM
xerox445
Oct 20, 2003 10:15 AM
