CKF - crank fluctuation sensor error (code 54)
Old Jul 23, 2007 | 07:17 PM
ExCiViChYbRiD's Avatar
Default CKF - crank fluctuation sensor error (code 54)
need help in what would set this code off. Also about how much would I be looking at to fix the problem? Any help would do.
Old Jan 12, 2008 | 04:15 PM
thrty8street's Avatar
Default Re: CKF - crank fluctuation sensor error (ExCiViChYbRiD)
up, I got this aswell on a d16y8 (obd2). Need some answers
Old Jan 12, 2008 | 06:05 PM
RYNO48's Avatar
Default Re: CKF - crank fluctuation sensor error (thrty8street)
I don't think your going to get a whole lot of responses. I had this problem on a EM1 w/Vortec supercharger and we could never find out what was causing it. I assumed that the belt drive had to do something with it. But since both of you are most likely not running it i'm also interested in finding out some causes.
The only thing I ever really came up with was that the senor was picking up a slight miss or a cylinder that wasn't producing like the others. In our case i think it was picking up a cylinder that was about to go bad cuz the #4 cylinder went down a couple of months later.
Old Jan 12, 2008 | 08:50 PM
D16z6BoostedEK's Avatar
I had the same problem later when I blew the motor I checked it and the altenator belt spliced into the wires causing to throw the code so u mite wanna check that out
Kyle244R948
Aug 8, 2013 08:52 PM
LS_VTECteggy
Jul 5, 2010 07:57 PM
russianroulette
Jan 16, 2004 05:47 PM
