checking timing
Old Aug 18, 2002 | 09:13 PM
Brian_92GSR's Avatar
New User
Default checking timing
Without the lower timing belt cover and the mark to use as a reference, is it possibile to check timing? I've got a craftsman timing light that is adjustable. Do you have to have that mark on the cover, or is it possible to use an adjustable gun without it?
Old Aug 18, 2002 | 10:32 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: checking timing (Brian_92GSR)
Nope, you need the cover because it has the TDC mark on it.
Old Aug 19, 2002 | 07:22 AM
X2BOARD's Avatar
Default Re: checking timing (B18C-EJ1)
Don't you point the gun at the mark on the crank pulley ? Didn't know the mark on the plastic cover had anything to do with a timing gun....
<---X2, who's never actually used a timing gun.
Old Aug 19, 2002 | 07:23 AM
Spade's Avatar
Go here.
http://www.c-speedracing.com/howto/timing/timing.html
SilvrBullet GSR
Nov 20, 2007 12:42 PM
dem0nk1d
May 22, 2007 11:00 AM
Steak84SS
Jul 3, 2005 09:26 PM
dsCRXsi
May 2, 2004 04:32 AM
turbodsmpower
Jul 10, 2003 08:48 AM
