Cheap go fast mods...what do you have
Old Feb 1, 2003 | 11:42 PM
SSBP DC2's Avatar
Default Cheap go fast mods...what do you have
i just bought another GSR to start over. so far i've done all the required maintainance and tune up etc to bring the car to mod-ready status. Compression came in at 235, 230, 235, 240...woohoo!
just did the home depot icebox and the car feels awesome.
what other cheap/diy mods (under 200) have you guys done to your motor?
keep in mind i want to keep the stock exhaust manifold and cams since i'll be boosting in the near future.
thanks
[Modified by SSPB DC2, 8:43 AM 2/2/2003]
Old Feb 1, 2003 | 11:53 PM
Al Bundy's Avatar
Default Re: Cheap go fast mods...what do you have (SSPB DC2)
Well this is not a go fast mod, but its a cheap DIY mod. The type r rear swaybar. Very big difference.
Old Feb 2, 2003 | 02:15 AM
SikofFalln's Avatar
Default Re: Cheap go fast mods...what do you have (red240ne)
Yea, get a good suspension setup. Polyurethane bushings all around, strut bars, and aftermarket sway bars. Get some bigger rotors/calipers, steel brake lines, and a good set of "H" rated tires. After all of that you should be able to handle your car when it's boosted.
Didn't they say under $200?
Old Feb 2, 2003 | 03:19 AM
ill phil's Avatar
Default Re: Cheap go fast mods...what do you have (BseriesPWR)
My ITR intake arm was cheap and made a large improvement (imo) over my stock B16 intake arm.
Old Feb 2, 2003 | 04:19 AM
bartek_b's Avatar
WTF??? what is the home depot icebox??????????????????
Old Feb 2, 2003 | 08:20 AM
JLange's Avatar
Default Re: Cheap go fast mods...what do you have (mugen85r)
the home depot icebox is making your own copy of the Comptech Icebox from parts at home depot, at a fraction of the price
as far as your go cheap mods, i dont know if all cheap mods apply, or if you are only looking for fast ones, but some that are cheap ones is
integra type r trunk brace
Brake Master Cylinder Brace
i think weight removal of things you dont need can help you pick up some speed
Old Feb 2, 2003 | 09:58 AM
spettinger's Avatar
Default Re: Cheap go fast mods...what do you have (jtintegra)
what materials did you use for your home depot icebox? is it airtight to the body, so no air gets in from the engine bay?
Old Feb 2, 2003 | 10:06 AM
Arsenal's Avatar
Default Re: Cheap go fast mods...what do you have (2ndhandCRX)
I got the ducting from Home depot for 3.99, I routed it to my front air dam and the air oges straight in, then to the filter, wether it works or not I don't know, I assume so as direct cold air being forced in? I then made my own Cold air box around the filter from insulation, and painted enamel black, looks good, pics later.
[Modified by Arsenal, 7:12 PM 2/2/2003]
[Modified by Arsenal, 7:13 PM 2/2/2003]
Old Feb 2, 2003 | 10:38 AM
T3's Avatar
T3
Trying taking out everything that you dont want in your car.Or strip the interior.
Old Feb 2, 2003 | 05:06 PM
SSBP DC2's Avatar
i believe there's the black pcv pipings at HD and there's the white pipings. I went with the white ones since it was lighter & cheaper, as well as the connectors. I desiged the pipings so that it is also a ram-air from the front opening, short of like that red/blue integra, just with piping and not an air duct. It is definitely independent from the heat in the engine bay. Suspension wise i've already done the R rear sway bar and the R strut brace. Anyone else? Should be alot of mods available for under $200 each mods right? thanks guys for participating.
-demitri
Old Feb 2, 2003 | 05:51 PM
Kamin's Avatar
Cheap, Reliable, Fast.
choose 2.
you can only have 2 and never the third.
Old Feb 2, 2003 | 06:19 PM
McFly's Avatar
Default Re: Cheap go fast mods...what do you have (Kamin)
choose 2.
Old Feb 2, 2003 | 06:24 PM
owen_the_soyboy's Avatar
if you do labor yourself to save money, you can take your flywheel and crank pulley to be lightened.. that'll be less than $200
Old Feb 2, 2003 | 08:21 PM
SSBP DC2's Avatar
choose 2.
this is old news to me
homedepot icebox = cheap, fast, and 100% reliable buddy
Old Feb 2, 2003 | 09:38 PM
Starrman85's Avatar
u should get stickers!!!! j/k
Old Feb 2, 2003 | 10:01 PM
Kamin's Avatar
choose 2.
yea but how many mods can you do that are cheap and reliable?
not many.
Old Feb 2, 2003 | 10:14 PM
NightmareApex's Avatar
well you can take out ur power steering(ill never go back, feel the road), ur ac( doesnt really get that hot 2 me) and crusise control( dont cruise). for 200$ u can get cam gears and a fuel preasure regulator( if tuned u can get some good hp)
-fuel presure regulators like 60$ B&M
-cam gears ive seen 50-200$ check recycler
- reprogrammed ecu 150-200 very good hp gains, I can refer you to a place if you live in LA, or close to it.
-bars, sway bars around 200 have seen a set of eibachs go for 100$ on the recycler
-strut bars, check ebay they have like package deals, there off brand but they get the job done
ummm damn 200 isnt alot hehe
Old Feb 2, 2003 | 10:18 PM
SSBP DC2's Avatar
choose 2.
not many.
yeah but one case proved to above statement false, now back to the drawing board
that's how science works, you have a theory until there's one case which proves it wrong
as for the mods, i was thinking $200 for each mod, that's not really cheap but more on the less expensive side. I could always start building up my motor for boost-friendly status.
where in LA do you have the hook-ups on ecu re-programming?
thanks
Old Feb 2, 2003 | 10:37 PM
Kamin's Avatar
sorry but 15's isnt fast.
unless your cracking 13's with your cheap mods, you arent fast.
and your not gonna get there with all the **** in home depot.
so your car is still slow and reliable.
Old Feb 2, 2003 | 10:47 PM
SSBP DC2's Avatar
haha okay
anyone else care to share and not circumvent?
thanks
-demitri
Old Feb 2, 2003 | 10:48 PM
Starrman85's Avatar
how much weight will u actually save with takin out cruise control? cuz i never use that either.
Old Feb 2, 2003 | 10:49 PM
Kamin's Avatar
just proving my point man
if your into track racing look into brake ducts, costs about 20$ and cools the brakes my a HUGE margin.
Old Feb 3, 2003 | 07:56 AM
SSBP DC2's Avatar
Default Re: Cheap go fast mods...what do you have (STARRMAN85)
i doubt you save much weight since it's only the black box & a couple of wires.
if your car is a daily driver, you'll disable to ability to save gas w/o cruise control
-demitri
Old Feb 3, 2003 | 10:28 PM
SSBP DC2's Avatar
Old Feb 4, 2003 | 05:14 AM
wm5holla's Avatar
Comptech Icebox is a what?
