Charging an AC system: How much Freon is necessary?
Old Jun 10, 2018 | 10:17 PM
zedjr's Avatar
Default Charging an AC system: How much Freon is necessary?
I have evacuated and charged with so far 2.5 to 2.8 cans. All 12oz cans. My pressure readings are 240 high side and 40 low side at 94 degrees ambient temp at idle. My compressor never cuts off until ambient temp gets down to 80 degrees or rpm's are above 1500. My system calls for 24.5 or 30 oz. Am still not sure if 24.5 is right or 30 oz. 30 was for the previous r12 system. This is r134a. How much gets stuck in lines i wonder. I seen a tutorial where guy used 4 cans on same exact year accord for 134a system. I'm thinking i need about 6 more ounces in system but then there has to be more than 24.5 oz in system already. System does work alot better than driving and at idle i guess the pressure on high side never get high enough to cut off compressor due to the high pressure switch.
Am moving this post to 90-2002 accord section
Old Jun 11, 2018 | 01:31 AM
holmesnmanny's Avatar
Default re: Charging an AC system: How much Freon is necessary?
depends on the vehicle
Old Jun 17, 2018 | 01:39 PM
2fat2furious's Avatar
Use ac gauges or risk blowing seals in compressor bruh
Old Jun 21, 2018 | 08:41 AM
canister's Avatar
5 Year Member
Default Re: Charging an AC system: How much Freon is necessary?
I do not use R134, and instead use Duracool. It takes 2 cans of Duracool to charge an evacuated system under vacuum, and one can to top up a system which leaked itself down to atmospheric pressure.
Old Jun 21, 2018 | 09:35 AM
thisguyaves's Avatar
Duracool the brand, but R134 the refrigerant type. Your lack of that knowledge scares me.
Old Jun 21, 2018 | 09:41 AM
Upon further reading, because I like knowing things, Duracool uses their own blends, but it is basically R12a which is R134 compatible. Still, duracool is just a brand.
Old Jun 21, 2018 | 10:48 AM
canister's Avatar
5 Year Member
Who told you that? Duracool R12 is highly purified propane and a replacement for R12 and R134a. If you don't know, read technical info on their web site. From here I can tell I know tons more about automotive AC than you.
Old Jun 21, 2018 | 12:30 PM
You probably do, knee jerk reaction sorry. Googled it after posting about it, shame on me. Live and learn.
Old Jun 21, 2018 | 02:24 PM
canister's Avatar
5 Year Member
No sweat!
Old Jun 21, 2018 | 03:53 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Most automotive professionals tend to err on the side of caution. DIYers would do well to follow these simple guidelines as well:
https://www.epa.gov/snap/ten-questio...ve-refrigerant
There is no legitimate reason to use a gas substitute.....
Old Jun 21, 2018 | 03:58 PM
canister's Avatar
5 Year Member
I am not surprised with these replies, as there is a hostile anti-Duracool campaign going on in the US. But up in Canada I, and a million more drivers, use Duracool. Cheers!
Old Jun 22, 2018 | 07:58 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Honestly ,my only objection to it is that there is no logical or legitimate reason for using it. Also,that it has no OEM approval.
In my experience when an item is brought to market,OEM manufactures will jump all over it, if it is superior to what is readily available,in their quest to one up each other.
Old Jun 22, 2018 | 10:25 AM
canister's Avatar
5 Year Member
Duracool is superior to R134 in many areas: it is cheaper, it is non-ozone depleting, it doubles as a lubricant, and it is easier on the compressor as only about 1 lb of Duracool is required for 2lb of R134 meaning the compressor is using 1/2 of HPs, its molecule is larger, so it is less prone to leaking.
Truckers in Canada use virtually no R134 but line up for Duracool cans, and its utilization in passenger cars is growing. Legitimate or not, there are many good reasons to forgo R134, which requires highly toxic Fluorine and Chlorine to be produced.
Old Jun 26, 2018 | 09:11 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Its not. At all. (at least in the US)
Compressor lubricants are like motor oil. Different compressors require vastly different viscosities. How does this manage to cover the spectrum of these requirements?
LoL, who told you that? Thats not how it works....at all.
Legitimate or not, there are many good reasons to forgo R134....
Still waiting on you to list some of them.
Im curious,if this refrigerant is so good,why do you think manufactures did not use it instead of R134a?
Even better, why was this refrigerant not even considered during the decade long study and testing for the replacement of R134a?
Why was R1234yf chosen?
Old Jun 27, 2018 | 05:49 AM
canister's Avatar
5 Year Member
I am a user or Duracool, and do not get paid for promoting it. If you need answers, you can contact the manufacturer and hear their side of the story. It was convincing enough for me, and thousands of truckers who lined up to buy it when I was at the store over the last 20 or so years.
Also I cannot speak for "manufacturers", whoever they are. You can contact them and ask as well.
For my upcoming AC repair on the Honda and Nissan I will buy a few more cans of Duracool.
Old Jun 27, 2018 | 07:36 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
No problem.
You spoke with authority on the subject earlier,I made the assumption that you knew what you were talking about.
Carry on.
zedjr
Jun 12, 2018 11:40 PM
Drew9464
Honda CR-V & Element
Aug 2, 2015 11:50 PM
Alex E
Jun 17, 2014 09:23 PM
greenteagod
20
May 8, 2014 08:25 PM
nixadm
Jul 5, 2004 08:59 PM
