Cel Code 9 Assistance Please
My 99' B18b1 teg is flashing cel code 9.
Its said that the code is: CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor * invalid code for throttle body injection Hondas ** invalid code for V6 engines Where is this sensor and how 'critical' is this problem? I havent noticed any performance decreases, but I would like to get this problem fixed as soon as I can. I would appreciate any help! Thank you very much! https://honda-tech.com/forums/images...es/emsmile.gif |
Re: Cel Code 9 Assistance Please (4DoorTeg)
bump
i believe its in the dist. try resetting ecu to see if it comes back
Re: Cel Code 9 Assistance Please (salbaje)
thanks for the reply! https://honda-tech.com/forums/images...es/emsmile.gif
Yea, i've tried resetting the ECU... The light usually comes back ~2-3 days after with ~150miles of driving. I've taken off the distributor housing (cap) and wasnt able to get any further because i wasnt able to take off the rotor.. But should the light turn off if the problem is solved? or do i have to always reset the ecu? Thanks |
You sure its not cel code 90. Gas cap integrity might be lost.
Re: Cel Code 9 Assistance Please (97hb)
hmm.... you have a good point there.... Im on OBD 2
I wouldent know how to read 90 when the light flashes... so it might acutally be How would i know that its 90 instead of 9? :hopeful: |
It would flash slowly if its 90 and fast if its 9. You can't really compare though. If you have an autozone near you, they will check the code for free.
