Car wont start?
Ok here goes.I have a boosted B series.The car is stroked and boosted running the aem EMS and aem cdi.The problem is after I had the car caged the car will not start it just keeps cranking but will not turn over.The cdi and ems was removed before the car was caged so I am leaning towards it not being electrical but I am at a loss of ideas.I was thinking maybe the coil sticks went bad or were damaged due to the weldi ng for the cage.Any ideas would be helpfull.
Have you determined if it is a fuel or spark issue yet?
If not, start there.
I assume when you say, "it just keeps cranking but will not turn over" you mean the starter motor is turning the engine over, [cranking] but engine will not fire, [start].
Questions...
Can you hear the fuel pump prime the fuel system when ign. key is turned to run, [not start?
What is the MM&Y of the car?94
Questions...
Yeah the fuel pump is priming and its a 99-00 civic si with a b16 in it.I havent checked for spark yet because the car has been apart for a while and its just recently has been put together again.
JDM Freakk
Jun 21, 2011 05:36 PM
