Car starts, run for while, backfires and then stalls?!?!?!?!?!?!
Old Mar 4, 2003 | 11:59 AM
Burke's Avatar
Banned
Default Car starts, run for while, backfires and then stalls?!?!?!?!?!?!
I have not driven my car for more than 50 miles in the past month, so we get a nice day and I decide to take it for a ride before i sell it. Warm it up for like ten minutes, go for a short ride, and I am going down a hill in like 2nd or 3rd and it backfires. So i take it out of gear and it stalls. and now it wont start. It feels like it wants to turn over, but after wont. Sometimes after cranking it, it will backfire with a nice loud pop.
I checked the battery, its fine. I thought it might be the fuel relay, but i can hear the fuel pump priming.
what's next distributor, cap and rotor. I am lost. please help. whats worse is that is that it will be sold in a couple days, and it wont go anywhere
I wound it out pretty good when it was running and no break up or anything.
thanks for the help
later
Burke
Old Mar 4, 2003 | 02:24 PM
Burke's Avatar
Banned
Default Re: Car starts, run for while, backfires and then stalls?!?!?!?!?!?! (Burke)
The rotor exploded. only small bits left now. Perhaps the screw came loose and then boom. Guess I can be glad that it happened to me now, then on the new owners ride home Time to go get a new distributor
Thanks for the help all
Old Mar 4, 2003 | 04:38 PM
Burke's Avatar
Banned
I just replaced the cap and rotor a half hour ago. but no luck. The shield that blocks the internals of the distributor was all chewed up too. it would not start with or without it. It sounds better though, no backfiring etc. it just wont start. I checked and all plugs are getting a spark, but no start. I have the wires connected to the dist correct, right?? it looks like this, looking from the passeger side
3 4
1 2
The number being the spark plug wire that corresponds with the cylinder.
I also tried jumping it hoping that my battery had lost its charge. I have been informed to call dealerships looking for that guard. Any body got any more ideas??
thanks a lot
burke
Old Mar 4, 2003 | 04:42 PM
fsarfino's Avatar
well I just had the same problem on my 90 teg. when you would crank it, It would crank then make that "pop" noise. After I replaced Cap/Rotor/and Coil it fired right up as far as the guard goes I did not have mine on my CRX w/B16a and it ran just fine without it
Old Mar 4, 2003 | 04:53 PM
Burke's Avatar
Banned
Default Re: Car starts, run for while, backfires and then stalls?!?!?!?!?!?! (fsarfino)
So it had that guard and you took it off or was it never there in the first place???
Thanks
Burke
ps - can i get coils at autozone????
Old Mar 5, 2003 | 04:58 PM
fsarfino's Avatar
well on my b16a I broke it when I was taking it off and I decided to see what happens when you dont have it and I found that it worked fine without it.
Old Mar 5, 2003 | 06:42 PM
Burke's Avatar
Banned
i fixed it!!!!! just the rotor.
thanks for the help.
later
burke
Old Mar 6, 2003 | 02:35 PM
fsarfino's Avatar
no problem.
BolivianFuego
Apr 9, 2011 09:34 AM
luisda4th
Feb 23, 2008 02:31 PM
Zion-I
Jan 24, 2007 07:34 AM
Burke
Mar 4, 2003 07:07 PM
Burke
Mar 4, 2003 02:22 PM
