car makes whining sound while cruising.
Old Jan 18, 2006 | 11:59 AM
. M i c h a e l's Avatar
dotmichael to you
Default car makes whining sound while cruising.
not sure if this belongs here..or integra..
i've noticed that sometimes while driving my car will making a whining sound from the front..it sounds similar to that of a supercharger whine..its a 90 ls.
sorry for the extreme lack of detail in my description, but there's nothing else i can say about it.
Old Jan 18, 2006 | 12:17 PM
old man neri's Avatar
Default Re: car makes whining sound while cruising. (. M i c h a e l)
Could be a wheel bearing going but it's hard to say just from a one word description of the sound it makes. You can check to see if there is any play in your front wheels.
Old Jan 18, 2006 | 02:34 PM
dotmichael to you
Default Re: car makes whining sound while cruising. (old man neri)
i think the sound intensifies as speed grows.
Old Jan 18, 2006 | 04:21 PM
Runnerdown's Avatar
Humming=low pitch. Whine=high pitch. Whats the better description.
Old Jan 18, 2006 | 05:25 PM
dotmichael to you
i said nothing about humming and i said whining a few times..like i said..its best described as s/c howl.
Old Jan 18, 2006 | 05:32 PM
Runnerdown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . M i c h a e l &raquo;</TD></TR><TR><TD CLASS="quote">i said nothing about humming and i said whining a few times..like i said..its best described as s/c howl.</TD></TR></TABLE>
Wheel bearings hum...I was trying to go somewhere with that. If it gets louder as your vehicle speed increases, first thing I think of is tire noise, bearings.
Old Jan 18, 2006 | 06:00 PM
R6E6I6D's Avatar
wheel bearing, differential, pulley or belt noise....
Old Jan 18, 2006 | 06:16 PM
QuangAlang's Avatar
is it only when you drive? or when the engine is revving?
Old Jan 18, 2006 | 06:25 PM
dotmichael to you
Default Re: car makes whining sound while cruising. (R6E6I6D)
i'm scared of it being the bearings..i know thats expensive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuangAlang &raquo;</TD></TR><TR><TD CLASS="quote">is it only when you drive? or when the engine is revving?
i'll let you know in 45 minutes or so.
Old Jan 18, 2006 | 06:27 PM
R6E6I6D's Avatar
u can always do the bearings urself pack them and what not....
wont be too bad and they will "if done correctly" last the life of the teggy
but dont jump to conclusions cause it sucks when its something else
Old Jan 18, 2006 | 08:03 PM
dotmichael to you
it seemed to do it only when revving. i was rolling at about 30 and i let the clutch in..revs fell and the sound went with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6E6I6D &raquo;</TD></TR><TR><TD CLASS="quote"> differential</TD></TR></TABLE>
i've had the biggest feeling the past couple weeks that its got something to do with the trans.
now..in the event its my bearings..what can happen if i dont replace them asap?
Old Jan 18, 2006 | 08:34 PM
turbochargeb18c's Avatar
BANNED
how tight is your timing belt?...if your timing belt is to tight it'll whine like that too...
Old Jan 19, 2006 | 12:06 AM
-ILLICIT-'s Avatar
Default Re: car makes whining sound while cruising. (turbochargeb18c)
i put my money on the g/box bearings, my 79 mini did this so i sold it, woulda cost me about 1k to fix dunno for a honda....havent lasted long though considering mine was 26 y/o lol and they just went, because as you when you put clutch in it goes away so its DEF not wheel bearings anymore, gotta be trans by that descrip
-|saac|-
Old Jan 19, 2006 | 12:38 AM
R6E6I6D's Avatar
Default Re: car makes whining sound while cruising. (-ILLICIT-)
if its aloud *** whine its most likely ur tranny, and im so very sorry
My trans did the same thing before it exploded
although it was very loud and noticable but only under a load, jack up the front put it in gear and row through em to see if its the trans
if not it could be something much easier to replace suchas a wheel bearing
Old Jan 19, 2006 | 01:38 AM
what is the level/condition of your gear oil/MTF, when was the last time you changed it?
Old Jan 19, 2006 | 10:18 AM
dotmichael to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6E6I6D &raquo;</TD></TR><TR><TD CLASS="quote">if its aloud *** whine its most likely ur tranny, and im so very sorry
if not it could be something much easier to replace suchas a wheel bearing </TD></TR></TABLE>
its not THAT loud. its barely noticeable..but i cant tell sometimes..helps when i roll down the window and turn the heat off..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">what is the level/condition of your gear oil/MTF, when was the last time you changed it?</TD></TR></TABLE>
i just bought the car recently and its been sidelined and i havent had the chance to change the trans fluid which has been high on my to-do list.
Old Jan 19, 2006 | 10:25 AM
That may be because the wind sound blocks out the whinning sound. Got me though.
i just bought the car recently and its been sidelined and i havent had the chance to change the trans fluid which has been high on my to-do list.</TD></TR></TABLE>
Do it now. If it is your tranny changing the MTF or just making sure there is enough may buy it some extra life.
Cheers.
Old Jan 19, 2006 | 03:11 PM
error's Avatar
check your timming belt. see if you can twist it past 90 degrees or so. sounds like it might be too tight.
Old Jan 26, 2006 | 12:48 PM
96ls's Avatar
Default Re: car makes whining sound while cruising. (error)
i've heard alternators that have bad bearings whine like what you are describing. But anyway, bump for a resolution
Edit: this car = red headed step child
Old Feb 1, 2006 | 09:30 AM
sloweh3's Avatar
Default Re: car makes whining sound while cruising. (96ls)
Mike, on my zc on my old ef, I had the same noise. It ended up being the alternator.
As for the wheel bearings, they wouldn't whine, it would more of a hum.
Check the belts as well, as they could be doing it. Pm me if you check out all of this and the problem doesn't go away man.
Old Feb 1, 2006 | 11:32 AM
nevamind's Avatar
I would do a visual check on all the drive belt for sign of dried or crack, and check the tension. With the hood open try rev the engine, if it the belt then you can hear it as the engine rev.
Old Feb 1, 2006 | 01:30 PM
texastype_r's Avatar
Default Re: car makes whining sound while cruising. (nevamind)
im 100% sure its your timing belt did you put a new one on recently
Old Feb 1, 2006 | 08:05 PM
akb16's Avatar
Default Re: car makes whining sound while cruising. (texastype_r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by texastype_r &raquo;</TD></TR><TR><TD CLASS="quote">im 100% sure its your timing belt did you put a new one on recently</TD></TR></TABLE> 100% sure? really???
Old Feb 1, 2006 | 09:15 PM
sloweh3's Avatar
Default Re: car makes whining sound while cruising. (akb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akb16 &raquo;</TD></TR><TR><TD CLASS="quote"> 100% sure? really??? </TD></TR></TABLE>
LOL
Old Feb 2, 2006 | 02:04 PM
dotmichael to you
Default Re: car makes whining sound while cruising. (1point6ek)
alright..i notice it happens mainly when i let off the gas and its more of a whistle than a whine.
the timing belt was done a couple months ago, btw so i dont think its that.
