Car bogs out until it is fully warmed up
Old Nov 2, 2008 | 06:11 PM
Rukusmasta2's Avatar
Default Car bogs out until it is fully warmed up
My buddies car bogs out and misfires until the engine is fully warmed up. No CEL's and after its fully warmed up runs fine. What can be the cause, what should i check or replace.
Old Nov 3, 2008 | 02:48 PM
Default Re: Car bogs out until it is fully warmed up (Rukusmasta2)
BUMP
Old Nov 3, 2008 | 03:28 PM
GhostAccord's Avatar
What type of car is your buddy driving? Make/Model/Year.
Sounds like a fast idle thermal valve or it could be low coolant. I'd need to know what engine and throttle body set up is being used to take a better guess.
Old Nov 3, 2008 | 04:00 PM
Default Re: Car bogs out until it is fully warmed up (GhostAccord)
96 EK b16 stock TB. and its not the IACV it was messed up and replaced with a good one.
Old Nov 3, 2008 | 04:14 PM
How does it start/idle cold with the IACV disconnected?
Did you bleed the coolant system after you changed the IACV?
Old Nov 3, 2008 | 04:51 PM
never tried that,yes
Old Nov 4, 2008 | 02:01 PM
Old Nov 4, 2008 | 03:17 PM
mmuller's Avatar
Mad Scientist
o2 sensor?
Old Nov 4, 2008 | 04:56 PM
Default Re: Car bogs out until it is fully warmed up (mmuller)
woudlnt a faulty o2 sensor throw a code
Old Nov 4, 2008 | 06:57 PM
mmuller's Avatar
Mad Scientist
not all the time, usually you would see heater codes. but..
af could be lean till o2 heats up.
does it missfire badly?
chris d
Sep 10, 2015 03:35 PM
scooter2525
13
Dec 30, 2013 05:23 AM
kpop
Feb 18, 2008 04:40 PM
kHoA DoGG
Oct 31, 2002 11:44 AM
