Cant figure this out!?! DAC intake problem.
Ok well after completing my swap about a month ago, i realized that i had forgotten to put the hose from the valve cover to the intake on. When i went back to my friends, the box was gone, so we figured it had been thrown out. The reason im stumped is becaue the extension from the intake for the hose to go over is WAY bigger than the metal pipe from the valve cover. Is the hose supposed to slide into the extension off of the intake, i know that seems odd, but their is rubber lining in it and i cant figure the size difference out?
Thanks
-Dylan
Thanks
-Dylan
If the sizes are different, use a hose with worm gear hose clamps to couple the two.
If it's too tight, you can circumvent the metal "x" tube by running a hose from the nipple on the valve cover to the nipple on the intake. You can also just get rid of the metal "x" tube all together by individually running the coolant and PCV hose.
Wazup
Jun 28, 2019 09:33 AM
