Can someone help me w/ oil pump sensor question????
Old Dec 13, 2004 | 11:42 AM
MassScene's Avatar
Default Can someone help me w/ oil pump sensor question????
I have a 97 integra LS. When i bought it the previous owner put a obd1 GSR engine swap in the car. Well I was wondering if there was a way to had in the oil pump sensor to the block. I dont care if its a hackjob or not... as long as it works.
Old Dec 13, 2004 | 01:03 PM
drdisco69's Avatar
Default Re: Can someone help me w/ oil pump sensor question???? (MassScene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MassScene &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if there was a way to had in the oil pump sensor to the block.</TD></TR></TABLE>
Could you please repeat the question?
Old Dec 13, 2004 | 01:58 PM
MassScene's Avatar
Default Re: Can someone help me w/ oil pump sensor question???? (drdisco69)
LOL sorry tryin to sneak a few posts in while im at work. I need to know if there is a way to wire a crank sensor onto an obd1 engine. I dont care if its hacked on and looks like ***. as long as it works.
Old Dec 13, 2004 | 02:10 PM
hondaracing1on12004's Avatar
oil pump sensor or crank sensor?
Old Dec 13, 2004 | 02:25 PM
drdisco69's Avatar
Default Re: Can someone help me w/ oil pump sensor question???? (hondaracing1on12004)
The crank fluctuation sensor. The positioning is probably pretty important, as it helps determine a misfire condition, so I'm not so sure a hack job will work. Any other input from people who know?
Old Dec 13, 2004 | 02:40 PM
MassScene's Avatar
I forget what its called. Its the one obd2 engines have that obd1's dont
Old Dec 13, 2004 | 07:39 PM
PrettyLude's Avatar
its the crank position sensor
Old Dec 14, 2004 | 04:55 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">The crank fluctuation sensor.</TD></TR></TABLE>Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">its the crank position sensor</TD></TR></TABLE>No, that's in the distributor.
Tegbuild140
Nov 13, 2018 05:45 AM
kronicus
Apr 1, 2009 05:46 PM
schlong1
Oct 19, 2008 05:38 PM
warwagon
Jan 11, 2005 05:14 PM
Huee
Mar 1, 2004 12:53 PM
