can someone confirm whether a 90 teg has ELD?
Old Mar 30, 2010 | 07:01 PM
mikesrex's Avatar
Default can someone confirm whether a 90 teg has ELD?
I have a 90 teg that I had to temporarily run on a P28 and OBD1 dizzy until I could fix my non-OBD dizzy. I made a conversion harness from some 93 civic ECU plugs and a gutted non-OBD ECU I had laying around, and everything checks out when I do a continuity test for all the wiring. When I run the P28, I get an ELD code when checking for codes, and I can't remember if the 90 teg has ELD.
can someone confirm if the 90 teg has an ELD sensor? I am going to drop my B20VTEC as soon as I get the block back from the machine shop, so I want to make sure I have everything buttoned up on the car and my OBD1 conversion once I put the B20VTEC in. Just in case it matters, the teg is a 5 speed and an RS.
thanks
Mike
Old Mar 30, 2010 | 07:46 PM
ochocinco's Avatar
Default Re: can someone confirm whether a 90 teg has ELD?
No it does not.
Old Mar 30, 2010 | 08:33 PM
seanbev24's Avatar
X2 it doesn't. When I had my obd1 gsr motor in my 91, the eld was a stored code but didn't light the cel. It didn't affect anything.
Old Mar 31, 2010 | 05:00 AM
mikesrex's Avatar
thanks guys!
4209racer
Sep 24, 2015 06:29 PM
eg6civic1538
Sep 2, 2007 11:42 PM
Wes90civic
Jun 17, 2006 02:39 PM
