can I turn on VTEC manually?
Old May 3, 2002 | 07:38 AM
Sleeping's Avatar
Default can I turn on VTEC manually?
Can I manually turn on VTEC without a VAFC or ECM mod?
Old May 3, 2002 | 07:56 AM
mercury's Avatar
New User
Default Re: can I turn on VTEC manually? (Sleeping)
Yes. It's just 12V going to a solenoid. But I really doubt you want to do this manually...
Old May 3, 2002 | 08:07 AM
speedymon's Avatar
Default Re: can I turn on VTEC manually? (mercury)
Your vtec is configured to turn on at the most efficient point. Anywhere else and you would lose performance, gas efficiency, etc.... Unless you are well modified. And even then get a vtec controller and adjust it.
Old May 3, 2002 | 12:10 PM
tonyxcom's Avatar
Default Re: can I turn on VTEC manually? (speedymon)
yeah, just scream WAAAAAAAAAAAAA and push youself back in your seat.
Old May 3, 2002 | 01:03 PM
99VTECex's Avatar
New User
Default Re: can I turn on VTEC manually? (tonyxcom)
Yeah I would too like to know why you want to do this?
Old May 3, 2002 | 01:53 PM
Turbo Laser's Avatar
Default Re: can I turn on VTEC manually? (99VTECex)
Some guys have to do that with their minime swaps, so they wire up a button that turns on VTEC. DOn't do it, it's ghetto if you have to to save $$$ and gay if you think it will sound cool.
Old May 3, 2002 | 02:02 PM
AussieK24's Avatar
Default Re: can I turn on VTEC manually? (ZCTURBO)
Does a VAFC activate VTEC or does it get the ECU to activate VTEC. What I'm asking is "does the computer make any adjustments to settings (Injector duty cycle) to allow for VTEC".
Could VTEC be triggered by, say, a feed from a shift light????? Or would the computer need to know. I have no VTEC due to no speedo signal and was wondering if I could use a shift light tacho to actuate the VTEC soleniod as oppposed to the big *** light????
Old May 3, 2002 | 02:06 PM
Kamin's Avatar
Default Re: can I turn on VTEC manually? (b16a4me)
the fuel mapping stays the same (I THINK) if your vtec is working or not.
Old May 3, 2002 | 02:20 PM
Bombino's Avatar
New User
Default Re: can I turn on VTEC manually? (KAMiN)
well.. if its not, then the ECU is in limp mode.. and fuel gets dumped, hence different maps. (I think) heh.
Old May 3, 2002 | 02:22 PM
AussieK24's Avatar
Cool, thanks KAMIN.....does anyone KNOW.
Has anyone tried the shift light theory? Although I suppose if I'd have done the conversion properly the computer would work as designed
Old May 3, 2002 | 04:44 PM
Sleeping's Avatar
I want to temporary lower the vtec switch over point, say for one day. then, restore it to normal. I wanted to get a vafc, but I am wondering is there any other method for adjecting the vtec without a vafc.
where is the solenoid that you are talking about? is that the ecm in front of passager sit?
[Modified by Sleeping, 8:44 PM 5/3/2002]
Old May 4, 2002 | 05:46 AM
AussieK24's Avatar
Soleniod is located next to the dizzy. Has a single feed wire going to it.
Computer doesn't go into limp without VTEC it just doesn't go
So, is the fuel map the same with or without VTEC???????
Old May 4, 2002 | 10:23 AM
speedymon's Avatar
Two different fuel maps for Vtec engines.
Old May 4, 2002 | 12:51 PM
allmotorEG-SI's Avatar
I think the switch idea might be kind of fun for a day or so. install a little switch on your shift **** and anytime you want some extra power, just hit a little red button.
Old May 4, 2002 | 01:56 PM
tonydatyga's Avatar
ahahahaha, vrooom WAAAAAAA piiiishhunk! all this while I'm sleeping in class. 2 fuel maps, one limp one reg. Reg stays same if not in safe mode and only vtec engagement point is changed.
B18c1vicrx
Nov 11, 2007 02:35 AM
sasinorm01
Oct 7, 2004 12:08 PM
xvracing
May 1, 2004 01:49 PM
South Bay Surfer
11
Apr 24, 2003 10:34 AM
[626] SiRJKwIcK89Ef
Oct 10, 2001 06:37 AM
