can I re-use these pistons ???
One of my valves bent.....took the head apart and found this ....can this block be reused it has some light rust on the cylinder walls I removed most of it with WD-40
# 2-3
# 4-1
now this is the piston I'm skeptical about #3
Let me know what you guys think......thanks
# 2-3
# 4-1
The pistons look fine. The block looks ok too. Question is are the rings ok...only way you could tell if they're still in good shape is a compression test.
i wouldnt use them that dent can lead to a hot spot just get new pistons espically if ur gonna go for more power n u should get the cylider walls cleaned up while its already apart......u dont wanna have to spend more money later when it blows
taking it apart now
