can a block be removed without removing tranny
Old Jan 5, 2003 | 06:32 AM
hotintegranights's Avatar
Default can a block be removed without removing tranny
have a bad block would like to know if i can skip taking of the tranny?????
Old Jan 5, 2003 | 06:43 AM
Nix_TEG's Avatar
Default Re: can a block be removed without removing tranny (hotintegranights)
Probably, but it will be alot easier taking out the motor with the tranny still attached !! And putting it back in would be alot easier too !!
Old Jan 5, 2003 | 07:08 AM
qcoffey's Avatar
Default Re: can a block be removed without removing tranny (Nix_TEG)
You might be able to leave the tranny in but you would still have to unbolt it. It only takes a couple hours to remove the whole engine/tranny together. It would take you more time just jerking around trying to get the engine angled out so thet the input shaft of the tranny comes out of its splines on the clutch.
Just remove it as one.
Old Jan 5, 2003 | 07:09 AM
Chiovnidca's Avatar
It's easy with an auto. Not worth the trouble with a 5-speed.
Old Jan 5, 2003 | 08:32 AM
Pengo's Avatar
Default Re: can a block be removed without removing tranny (Chiovnidca)
it could be done. but why? it would be easier to just take the whole thing out and swap tranny over to new block while everything out. if you have experience doing a tranny swap with the block still in the car, you'll understand. just pull that whole thing out as one. good luck
-alan
Old Jan 5, 2003 | 10:31 AM
Nameless RB26's Avatar
Default Re: can a block be removed without removing tranny (Pengo)
Don't even waste your time thinking about doing that..
It'll be twice as hard as taking the engine out with the tranny.
Old Jan 5, 2003 | 12:26 PM
charjacq's Avatar
New User
Why would you want to do that? You have to obviously unbold the tranny from the block first. While you're there, just remove the tranny, it'll be much easier working on the engine.
Do it right the firt time and stay away from trouble. It's not worth cutting corners in the long run.
Old Jan 5, 2003 | 01:00 PM
Kamin's Avatar
Default Re: can a block be removed without removing tranny (charjacq)
just pull the entire engine/transmission
will be 100x easier.
Old Jan 5, 2003 | 01:52 PM
Chiovnidca's Avatar
Default Re: can a block be removed without removing tranny (Kamin)
Unlless it's an auto.
Old Jan 5, 2003 | 02:12 PM
guess i ll have to remove the tranny and your right it will make it easier to bolt it on to my other block... whatz was i thinking
Old Jan 5, 2003 | 02:13 PM
Pengo's Avatar
Default Re: can a block be removed without removing tranny (Nameless)
twice as hard? how so? unbolt the one mount on the driver side and let me know how you plan to pull just the block. better yet, lemme know how easy its gonna be lining everything back up when you put it back in.
Ep1dem1c
Dec 3, 2007 01:01 PM
Rod.
Jan 20, 2004 07:24 PM
xteg95
May 18, 2003 03:49 AM
Mario
Mar 15, 2002 07:36 PM
hybridcrx
Feb 28, 2002 04:38 PM
