A/C in hybrid ef problems. please help
Guys. i tried putting a/c back into my car this weekend. ran into soem problems.. first of all. i got all the lines (piping) in the engine bay from a 88-89 dx. heres my setup on my car 90 si w/ b16a3 with HCP motor mounts. and im using the 94 Delsol A/c Bracket.
First when i tried going to put the bracket in. the Crossmember was in the way by like 1/2 an inch. on the bottom of the bracket.. so i unbolt my crossmember and let it down to put the bracket on . Now i put the 94 delsol A/c Compresser in. it even take more space. Now that the a/c compresser is on the bracket.. I go try to put my crossmember back up . I find out that the compressor is now in the way . i cant put the crossmember back on. the compressor is now sittin lower than the bracket inself.
The other problem i have is that the piping does not run correctly onto the compressor. It seems like i have to bend it alot to get it right. even tho i got one on.. the piping was 1 inch too short..
If anyone who got through this problem.. and know how to fix it please help. Soi have to go get custom piping? and how do i go on gettin the compressor and bracket sit correctly
thanks guys..
thanks guys..
You may want to think about using one of the aftermarket cross-members for additional clearance.
As for the hoses, I'd recommend that you ask somebody that has a similar car if you can look under their hood. It is possible to have custom hoses made up if you have to. Stop by a Jeep dealer and ask them who does their "dealer" installed units. These are "kits" but normally have to be customized a bit by the installer. (BTDT on my 64 Chevelle with custom AC from Vintage Air)
Wes Vann
Wes Vann
Different a/c compressors have different a/c lines. You need to match the lines to the compressor in order for things to work without having excessive bending.
yah seems like your having ur share of fun. Why arent u using a HASport a/c bracket that uses a factory 88-91 civic A/C compressor and then you dont have to worry about doing custom lines.
Thats what i did
Thats what i did
Irev... thats exactly what im doin now. hehe had to find it out the hard way.. oh well thats how we all learn.. thanks guys
STK B16
Jun 1, 2003 09:18 AM
