Bump Stop in Rear schocks
Old Mar 29, 2003 | 04:07 PM
Bizarre's Avatar
Default Bump Stop in Rear schocks
Hey, I have a 94 Civic Si coupe and was wondering if I have to cut my bump stops in the rear shock. It's a 2 inch drop. These are the stock shocks. Also if I do have to cut them how do I remove the dust cover. Thanks
Old Mar 29, 2003 | 04:21 PM
the DR.'s Avatar
Default Re: Bump Stop in Rear schocks (Bizarre)
yes, you have to remove the dust cover, which will also mean you have to take the whole spring/shock combo apart
Old Mar 29, 2003 | 04:58 PM
Bizarre's Avatar
Default Re: Bump Stop in Rear schocks (SlicedBread)
I know I have to take the whole combo out. My question was, How do I remove the cover from the schock. Thanks
Old Mar 29, 2003 | 05:21 PM
Lord Helmet's Avatar
you need a wrench size 12 or 14mm (I forgot the size) and a allen wrench(again forgot the size ) to take the top of the cover off. warning: the stock shock and spring combo is under pressure so I recommend you be carefull taking it apart because it will unsprung from the compression it is under.
Old Mar 29, 2003 | 08:10 PM
dfoxengr's Avatar
Default Re: Bump Stop in Rear schocks (sleeperciv)
its lsides off when yo have it apart, and u ned to cut the stop
Old Mar 30, 2003 | 12:19 PM
Bizarre's Avatar
Default Re: Bump Stop in Rear schocks (hybridvteceg)
I figure out why I coudn't get the covers off. on top of the cover their is some sort of sleeve which was seized on. So it wasn't slidding apart. Thanks for all the help.
Old Mar 30, 2003 | 01:36 PM
dfoxengr's Avatar
use a hammer
Spoon Sports
May 10, 2009 10:48 AM
jbell
Honda S2000
16
Sep 18, 2008 06:26 PM
..::91TEG-G2::..
Audio / Security / Video
Aug 22, 2006 03:15 PM
chris3k
Mar 17, 2006 11:00 AM
4NOWJUSTADX
Sep 8, 2005 02:56 PM
