broken timing belt?
Old Apr 3, 2002 | 03:06 PM
96vteclude's Avatar
Default broken timing belt?
Hey guys, I just registered here but I've been reading the posts for awhile. I have a 96 Prelude VTEC and two days ago I started my car and it seemed fine. I drove about a mile roundtrip to pick my brother up from school. When I got back I turned off the car and a few minutes later I had to go somewhere else. However, when I turned the key the engine would started but idled really rough then died on me. I tried again and it won't start. I got a mechanic to come by and take a look at my car and he says that my timing belt is most likely broken. That's something I hoped I wouldn't hear. Well, if my belt broke while I was driving wouldnt I have heard it? Also, I'd think that the car would die on me in the middle of the street but when I was driving it, it still had plenty of power and idled as smooth as ever. So I'm not sure about the timing belt. If it is broken, I've heard that the engine would crank really fast but never start. My car doesn't crank that fast and I'm really confused now. Btw, I have about 53,000 miles on the car. Sorry for the long post guys but any help would be appreciated.
Old Apr 3, 2002 | 03:11 PM
fixhondas's Avatar
Default Re: broken timing belt? (96vteclude)
I doubt your t-belt is broken- however- take your oil cap off- have someone crank it while you look inside with a flashlight- if the cam moves, your belt is not broken. However that doesn't necessarily mean all is well with the belt. Do you have spark?
Old Apr 3, 2002 | 03:17 PM
Crazydave's Avatar
Default Re: broken timing belt? (fixhondas)
Lots of stuff.... check Fuel and ignition...
check valves
check oil
did you motor overeheat..
check compression... could be headgasket
erniecars's Avatar
since you werent driving while it broke (if it broke) there is a good chance your engine is fine and you just need a new belt.
Old Apr 3, 2002 | 05:22 PM
96vteclude's Avatar
Default Re: broken timing belt? (erniecars)
Hmm...do you think that maybe the t-belt is loose? Would that be a logical reason why it doesn't seem that its broken but still doesnt start?
Old Apr 3, 2002 | 05:50 PM
CivicEK.PDX's Avatar
bingo...
Old Apr 3, 2002 | 07:21 PM
96vteclude's Avatar
Default Re: broken timing belt? (CivicEK.PDX)
Oh...I'll be sure to check that out tomorrow. Thanks for the help guys.
Old Apr 4, 2002 | 03:41 PM
fixhondas's Avatar
if it's loose it can jump time and cause a no start
Old Apr 4, 2002 | 05:18 PM
Zeus Zore's Avatar
tjek the mainfuel rely !!! .......
i dont believe that it is the Tbelt !!! but would be easy 2 see if it is !!
Old Apr 4, 2002 | 05:27 PM
87posCRX's Avatar
Default Re: broken timing belt? (Zeus Zore)
its an inteference engine, so you REALLY need to check and see if its broken. if its broken, 80% chance your screwed.
patm95
Honda Civic (2001 - 2005)
Oct 4, 2013 06:29 AM
MurtazaDSM
May 28, 2012 12:11 AM
HGZ
Feb 25, 2009 09:20 AM
rokestah
Feb 3, 2003 04:20 PM
Sephro
Sep 30, 2002 06:50 PM
