Brake booster check valve direction?
Old Feb 4, 2010 | 10:11 AM
djnikko's Avatar
Default Brake booster check valve direction?
Hi all,
Can someone tell me which way round the brake booster check valve should be? I seem to get a hunting idle everytime I press the brakes, this is for a H22 EG civic.
Thanks in advance
Old Feb 4, 2010 | 02:07 PM
Scott_Tucker's Avatar
Default Re: Brake booster check valve direction?
Your brake booster diaphragm may be ruptured.
Old Feb 6, 2010 | 06:02 AM
djnikko's Avatar
Is there a chance it could be the seal? I did upgrade the brake booster a while ago so possibly I didnt tighten the nuts to spec. I'll check to se if they've come loose and i'll check for cracks in the hose.
Can someone tell me which way the arrow should point on the check valve? i.e. towards the brake booster or away from it? Thanks
Old Feb 6, 2010 | 07:14 AM
Egezzy's Avatar
Spongebrad Squarepants
towards the engine.
Old Feb 6, 2010 | 08:30 AM
Yes, away from the booster.
Old Feb 6, 2010 | 09:01 AM
thesmogman's Avatar
Yes away from the booster, and you can check it to make sure it is sealing by blowing thru it. One way you will be able to and one way you won't. It should not leak at all.
If dirty or leaks just blow some water thru it to clean it out.
Old Feb 6, 2010 | 10:43 AM
djnikko's Avatar
Thanks for the replies. It was facing the right way. Im about to do some more checks as found in the manual.
acarguy
Honda Fit
Aug 6, 2017 02:56 PM
Mad-Mike
Jul 9, 2011 05:22 PM
90civicstdgold
Mar 10, 2010 12:43 PM
crazyboy
10
Sep 15, 2009 08:04 PM
85mm LS VTEC
Mar 31, 2007 07:57 PM
