boring out sleeved z6
Old Jan 23, 2006 | 01:35 PM
CRX_Phantom1's Avatar
Default boring out sleeved z6
what is the max I can bore a sleeved z6 to? i was told that 78mm will give me a 1.8L motor. can I go any bigger or is that about it?
Old Jan 23, 2006 | 02:47 PM
hellshock2182's Avatar
Default Re: boring out sleeved z6 (CRX_Phantom1)
mine will be 79 mm but no turbo for me, I don't wanna risk it
Old Jan 23, 2006 | 03:00 PM
Default Re: boring out sleeved z6 (hellshock2182)
ok thank you. anyone else? i will be boosting and spraying this motor
Old Jan 23, 2006 | 04:37 PM
bump
Old Jan 23, 2006 | 06:16 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Phantom1 &raquo;</TD></TR><TR><TD CLASS="quote">what is the max I can bore a sleeved z6 to? i was told that 78mm will give me a 1.8L motor. can I go any bigger or is that about it?</TD></TR></TABLE>
A 1.8L z6 would need a 79.5mm bore. But it's best not to overbore it. Thicker sleeves = more boost, and boost &gt; displacement.
Old Jan 23, 2006 | 07:03 PM
v4lu3s's Avatar
RTFM
how much does the machinist who installed teh sleeves say you should bore it at most to?
Old Jan 23, 2006 | 07:08 PM
Default Re: (v4lu3s)
im actually buying the block off a buddy of mine. he said bore it to 78mm
Old Jan 23, 2006 | 08:02 PM
EnzoSpeed's Avatar
Default Re: (CRX_Phantom1)
78mm = 1.72L.
It's kind of a bad idea to go that big because you can only do about two rebuilds before the sleeves become useless. (assuming you do a .5mm overbore with each rebuild). Plus you'll have to buy a different set of custom pistons with each rebuild because no one makes them that big.
Old Jan 23, 2006 | 08:15 PM
Default Re: (EnzoSpeed)
I see. so should i just leave it bored at 76mm? b/c thats what it is right now
Old Jan 23, 2006 | 08:26 PM
EnzoSpeed's Avatar
I would leave it at 76. If you go to 78 you won't see any noticeable gains. Plus, if you ever melt a piston, you will always have a nice buffer to bore the sleeves out to 77 or 78.
Old Jan 24, 2006 | 04:43 AM
that sound like a good idea. thanks
koulaid
Oct 27, 2008 09:52 AM
CRX_Phantom1
Jan 28, 2006 09:10 PM
CRX_Phantom1
10
Nov 11, 2005 08:56 AM
drowzysleeper
Mar 28, 2005 08:43 AM
