Blocking off VTEC oil pressure sensor
Old Jan 19, 2004 | 07:25 PM
  #26
crxsirvtec's Avatar
Default Re: Blocking off VTEC oil pressure sensor (xzr12)
looks like some one stole it ...
Old Jan 19, 2004 | 09:51 PM
  #27
phatrick2332's Avatar
Default Re: Blocking off VTEC oil pressure sensor (machine4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">
as does mine ....</TD></TR></TABLE>
yea..your probably pre-obd2..
Old Jan 19, 2004 | 10:14 PM
  #28
mmuller's Avatar
Mad Scientist
Default Re: Blocking off VTEC oil pressure sensor (crxsirvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsirvtec &raquo;</TD></TR><TR><TD CLASS="quote">looks like some one stole it ...</TD></TR></TABLE>
for you non believers...
here is a better pic.
https://honda-tech.com/zerothread?id=737383
Old Jan 20, 2004 | 07:32 PM
  #29
xzr12's Avatar
its not an oil pressure switch , its a sensor
the solenoid is the vtec switch
my stock ecu doesnt need oil pressure sensor to switch my vtec on ... my ecu will turn the solenoid on when it simply reaches 5500RPM!
Old Jan 20, 2004 | 07:58 PM
  #30
PHiZ's Avatar
Default Re: (xzr12)
i don't know if I need to lend my weight to this argumnet. But certain JDM motors do not have the VTM sensor. Vtec Oil-Pressure Sensor. The sensor's purpose is to not allow vtec to engage without appropriate oil pressure.
MMuller is saying that it is the OBD2 motors that don't have the sensor. I'm willing to believe him. I have seen JDM motors with the sensor and without. It seems reasonable if it's a generational thing.
-PHiZ
Old Jan 20, 2004 | 09:46 PM
  #31
mmuller's Avatar
Mad Scientist
Default Re: (xzr12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xzr12 &raquo;</TD></TR><TR><TD CLASS="quote">its not an oil pressure switch , its a sensor
my stock ecu doesnt need oil pressure sensor to switch my vtec on ... my ecu will turn the solenoid on when it simply reaches 5500RPM!</TD></TR></TABLE>
sensor operated over a wide range(ex: map)
switch only has 2 on/off, the vtec oil pressure switch doesnt measure how much pressure there is; only if there is or not. just like the oil pressure switch on the block and ks
Old Feb 21, 2004 | 02:29 AM
  #32
ShakesTheKlown's Avatar
Default Re: (mmuller)
I can tell you for a fact that the OBD2 B18CR's do not have a vtec oil pressure sensor. I had to use the one from my D16Z6 for my ECU, and it is currently hanging right next to my vtec solenoid, not plugged into anything. Made me kinda worried first time I noticed it, but since I'm using the USDM ecu which looks for it, the guys who did my swap just left it hanging in there.
Old Feb 21, 2004 | 11:30 AM
  #33
Hullmotor's Avatar
96 and up jdm h22a don't have v-tec oil pressure swich.My 96 jdm h22a came whit no oil pressure swich but my 94 jdm p13 need that swich to engage vtec.
I was tinking that jdm 5th gen prelude have a stock v-tec controler in option.
Old Oct 14, 2025 | 04:08 AM
  #34
FIJIAN K24's Avatar
Default Re: Blocking off VTEC oil pressure sensor (4crx4me)
Originally Posted by That Dood
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote">
Huh??? What?? English do you speak it? Seriously?
And, if JDM cars don't have an "oil pressure switch", what exactly activates the engagement of the VTEC mechanisms locking pins. Magic? Hhmmm?</TD></TR></TABLE>
Ya that is english I am speaking....VTEC is activated off a RPM signal....and that signal activates the solinoid which locks force oil to lock the rocker pins which in turn hits the VTEC lobes causing the VTEC effect....learn something before you go and try to start telling people how things work...(wheres that damn hammer when I need it)
[img alt="JDM K24A3 05 Honda Accord Euro
Doesn't come with oil pressure sensor. There's no connector for it in the harness aswell. I guess the ECU assumes there's oil pressure and activates VTEC.
I have no engine codes either. "]https://cimg6.ibsrv.net/gimg/honda-tech.com-vbulletin/920x2000/screenshot_20251015_000528_chrome_743a7a09a31d24fd 15e19120ce54134c2f46009b.jpg[/img]
JDM K24A3 05 Honda Accord Euro Doesn't come with oil pressure sensor. There's no connector for it in the harness aswell. I guess the ECU assumes there's oil pressure and activates VTEC. I have no engine codes either.
Dave Brabant
Mar 15, 2018 11:26 PM
DDream
Sep 20, 2012 05:57 AM
h23vtec_dc2
May 19, 2011 10:38 AM
vladd
Jul 10, 2008 05:03 PM
PinkMaggit
Mar 12, 2007 05:43 AM
