Best way to align the cams TDC.
Old Aug 23, 2008 | 10:42 AM
ken2830's Avatar
Default Best way to align the cams TDC.
Im just curious as to what techniques people use to align there cams TDC wen installing back the timing belt. Everytime i try putting the belt on, the cams would tend to wanna move..any input would be appreciated.
Old Aug 23, 2008 | 10:50 AM
KooK's Avatar
Mustang Sally
Default Re: Best way to align the cams TDC. (ken2830)
I yell and scream at them. Then I threaten them that I will break out my DOHC lock tool, (part number 36880) which I found at my friendly local Carquest Auto Parts store for a reasonable $39.69 plus tax.
Old Aug 23, 2008 | 02:41 PM
1992Si's Avatar
I believe a 5mm hex wrench will work.
Or a number 9 drill
Old Aug 23, 2008 | 03:15 PM
ken2830's Avatar
Default Re: Best way to align the cams TDC. (KooK)
LMAO.Yea I cant seem to find them at local parts store like autozone or pepboys or advance auto.
Old Aug 23, 2008 | 03:56 PM
Jeffrey9's Avatar
Just find some 5mm (not sure on size) pin punches to jam in the cam towers when you're aligning them.
Old Aug 23, 2008 | 04:01 PM
ken2830's Avatar
Default Re: Best way to align the cams TDC. (Jeffrey9)
Where would i Place the punch? Because i dont see no holes or anything that would allow me to stick a punch in and get the cams to stay in place.
Old Aug 23, 2008 | 07:02 PM
rwcdrums's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ken2830 &raquo;</TD></TR><TR><TD CLASS="quote">Where would i Place the punch? Because i dont see no holes or anything that would allow me to stick a punch in and get the cams to stay in place.</TD></TR></TABLE>
bump I would like to know as well. I am currently putting a new motor together and the only holes I see don't go all the way thru the cams. I was able to hold the cam gears with the arrow pointing up on both of them and slip the timing belt on but it seemed too easy so I'm not sure I did it right.
Bump for some advice.
Old Aug 24, 2008 | 08:17 AM
ken2830's Avatar
buummppp
Old Aug 24, 2008 | 08:20 AM
DonF's Avatar
Default Re: (ken2830)
They are in your cam support rails on cylinder #2, just like your Helms manual says.
Old Aug 24, 2008 | 01:00 PM
Jeffrey9's Avatar
Default Re: (DonF)
There should be some small holes through the towers that will plug into similar holes on the cams themselves. The two will come into line when the cams are TDC. Pull off the valve cover and start looking, once you see them it will make perfect sense.
The cams don't like to be in exactly TDC as the valves on the intake side are just barely opening and want to snap back closed, if you're clever when you switch the timing belt, you can use the tension of the timing belt to pull the cam into the right position while you put it on.
Old Aug 24, 2008 | 04:59 PM
non-VTEC's Avatar
i never used the aligning holes. i just eveyball it and work the timing belt on over the gears while using a wrench to slightly turn/agjust the cams as they move.
Old Aug 24, 2008 | 05:18 PM
KooK's Avatar
Mustang Sally
Default Re: Best way to align the cams TDC. (non-VTEC)
How the hell do they not they carry it? It's a Lisle tool, everybody has them!
Damn cheap here.
http://www.tooldiscounter.com/...36880
Old Aug 24, 2008 | 08:14 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i never used the aligning holes. i just eveyball it and work the timing belt on over the gears while using a wrench to slightly turn/agjust the cams as they move.
JdmTosca
Oct 6, 2008 09:57 PM
vinuneuro
19
Sep 15, 2008 09:04 AM
Dr.Colossus
Jul 8, 2008 08:45 AM
2000EK4
Apr 17, 2007 03:56 PM
InfamousRS
May 12, 2002 03:02 PM
