Best NGK's for Nitrous?
Old Jun 5, 2003 | 08:47 AM
Goldfingiz's Avatar
Default Best NGK's for Nitrous?
Hey guys, my ZEX plugs failed after a weak, so I was wondering which NGK's are the cold ones that I should be running with n2o..
Thanks!
Old Jun 5, 2003 | 08:55 AM
1_bad_EF's Avatar
Default Re: Best NGK's for Nitrous? (Goldfingiz)
1033's= bcpr7es
Old Jun 5, 2003 | 08:56 AM
QKRTHNU's Avatar
The most common for Hondas would probably be either of these two.
NGK BCPR7EY-11 (14mm Thread, 3/4" Projected Tip, 5/8" Hex .042"gap)
NGK BKR7E Non-projected tip
Both these plugs are 7 heat range. Going from a projected tip to a non-projected tip is equivilent to 1/2 heat range colder.
Old Jun 5, 2003 | 09:23 AM
Goldfingiz's Avatar
Default Re: Best NGK's for Nitrous? (QKRTHNU)
Which of the two are better? Do either require gapping? If so, what should I gap them to?
Thanks
Old Jun 5, 2003 | 10:03 AM
evo's Avatar
evo
New User
How about HKS S45i heat range 9?? Good for Nitrous?
Old Jun 5, 2003 | 11:25 AM
VRD^don's Avatar
Default Re: Best NGK's for Nitrous? (evo)
how about some champion copper plugs. they happened to work well for my friend running nitrous too..
hondaeg8
Sep 26, 2004 11:46 PM
blackem
Mar 8, 2004 11:12 PM
dseriessol
Sep 30, 2003 01:07 PM
stupidfast
Oct 3, 2002 05:29 PM
