Battery Charger Bulb Out / Question
Old Apr 17, 2013 | 02:24 PM
grog's Avatar
Icon2 Battery Charger Bulb Out / Question
I've got a cheap car quest battery charger that also works as a battery tender. The indicator light that illuminated when fully charged is no longer working. I tried a different LED but the voltage was too low to light it up.
My question is how can I test the charger to see if it still functioning properly?
I know I could run a multimeter inline with one of the cables but it will burn it up right quick. I can check the battery's charge but that doesn't seem to tell me much.
Maybe a continuity test?
I only want to check if the charger is pulsing on a and off when its "tending' the battery.
Anyway I would love to hear peoples opinion on how to test it, or whether to worry about it.
Old Apr 17, 2013 | 06:03 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Battery Charger Bulb Out / Question
How does checking that the battery is indeed maintaining a charge not indicative of the battery charger/tender not working? Explain that please.
Old Apr 17, 2013 | 06:55 PM
fcm's Avatar
fcm
Old Fart
Got to agree with grumblemarc, the only other way I can think of is to connect up a meter to the batt. along with the charger, [parallel] see what voltage is, [should be around 12.5V on a fully charged batt.] turn on the charger, see what voltage is, [should go up, how much will depend on the charger] and sit down and wait to see if charger "pulses" off, [voltage should go back down to around 12.5V] and then wait again to see if the charger "pulses" back on, [voltage should go up again].
Kind of a PITA, but other then getting the correct LED, I only see those two as options. 94
Old Apr 18, 2013 | 08:09 AM
grog's Avatar
Thanks for the replies. Maybe my multimeter is just shoddy, when i've taken readings on the battery it jumps around too much to see a base line to compare with.
Maybe testing it on a dead-ish battery will make it clearer, anyway thanks again and I'll re-check.
VTEC_Du_Ma_Mai
Mar 20, 2008 04:48 PM
jules_ca
Dec 8, 2007 05:47 PM
goliyong
Honda Civic (2001 - 2005)
Jun 20, 2007 06:31 PM
RUBZERK
Jun 12, 2004 10:48 AM
TIRENECK
11
Dec 12, 2003 09:05 PM
