Barely idling after vacuum leak.
1993 Civic Cx with B18b1
Still debugging and rebuild, and swap install.
Engine was idling pretty well, but I noticed what sounded like a vacuum leak. I traced it to the brake booster. I removed the hose and plugged. The leak sound went away, but the engine revs dropped to about 100-200 rpms maybe slower, nearly stalling. Uncorking the brake booster hose the idle retrurn to a little above normal.
I'm wondering if the ecu needs clearing, if its the IACV, or if I should adjust the idle screw....
I'm also wondering if my brake booster needs to be tested to see if it will hold a vacuum.
There is definitely a vacuum leak at the bottom of the master power (brake booster) unit.
There is also a humming sound coming from the IACV with the key on position.
DUKE LADUKE
25
May 10, 2011 09:21 AM
B16A CRX
May 6, 2009 04:17 PM
stripes777
Apr 27, 2008 02:34 PM
