balancing tires??
Old Feb 8, 2003 | 10:04 AM
sslude's Avatar
Default balancing tires??
what exaclty do they do when they balance your tires? thanks
Old Feb 8, 2003 | 10:14 AM
91_hatch_si's Avatar
Default Re: balancing tires?? (sslude)
balance it so the tire is even on all sides
Default Re: balancing tires?? (91_hatch_si)
they put the wheel on this machine and hammer in some weights to the wheel
Old Feb 8, 2003 | 11:14 AM
sslude's Avatar
hammer in weights into the wheel? please be more detailed.
Old Feb 8, 2003 | 12:10 PM
XxWildHorsexX's Avatar
when one side of the tire weighs more then the other you gotta counter balance the weight or the tire wil just bounce when driving at a high rate of speed ... no tire is perfectly round even when they are now so it is always nessary to balance them when you buy new tires
Old Feb 8, 2003 | 12:18 PM
b19coupe's Avatar
Unbalanced wheels will cause vibration. If they are on the front, you will feel it in the steering wheel, usually above 40 mph. On the rear, it is less noticeable, you feel it more in the seat of your pants. Wheels are balanced on a machine that spins the wheels and then tells the operator where to put the weight and how much weight is required. There are weights that clip on to the outer lip of the wheel, and there are tape weights that attach to the inner portion of the wheel (for custom wheels, many of which don't have a lip for conventional wheel weights).
[Modified by b19coupe, 1:18 PM 2/8/2003]
^_^
May 18, 2007 07:52 AM
gyrmaersk
Apr 21, 2006 12:57 AM
Asahi
May 23, 2002 05:11 AM
