B20... lightweight components
Old Jan 23, 2002 | 10:52 PM
. o 69 o .'s Avatar
Default B20... lightweight components
I am going to get a spoon 4 kg flywheel, and a CTR crank pully (drives only the alternator)on a B20.. considering the weight difference on both sides of the motor, is it a good idea to get the bottom end balanced? I don't like to waste cash, and blow up motors.
What would be a good clutch for a b20 with mild mods? (Flywheel, pulley, cams, intake manifold, LSD tranny, Z-10 R.R) I do want to be able to put the power down
Also, how can i get this low rev pig to rev a bit higher? I am looking for about 8500-9000 peak rpm. I want to be able to give some of the vtec guys a good run
Thanks for your input!
[Modified by B16B, 10:10 AM 1/24/2002]
Old Jan 24, 2002 | 09:10 AM
. o 69 o .'s Avatar
Default Re: B20... lightweight components (B16B)
up
Old Jan 24, 2002 | 03:39 PM
C1V1C's Avatar
If you want a high reving engine get a b16 or b18c, the b20 is not made for reving and theres no point since it makes it power down low. The higher you rev doesn't always mean more power. If you are set on it make it a crvtec and change the valvetrain.
Old Jan 24, 2002 | 07:27 PM
Kataku2K3's Avatar
Default Re: B20... lightweight components (C1V1C)
My friends CRVTEC is bored to 84.5mm has JE 13.0:1 pistons stock rods, Portflow b16 head, JUN type 3 cams and he revs that poo poo to 9,500 all day long. He says the rods are fine as long as you get ARP bolts. If i were to build this same setup i would just go with Eagle rods, they cost about 300-350. Makes power all the way up.......
cloviskilla
12
Aug 15, 2010 01:42 PM
feriotypeR
Engine Management and Tuning
Jul 20, 2008 05:17 PM
rare_db2
32
Jul 27, 2007 01:10 PM
Type-Rik_83
May 1, 2006 09:04 AM
REVOUTHIGH
Jun 24, 2004 04:54 AM
