b18b rod on a gsr crank?
Subscribe
May 12, 2004 | 06:56 PM
i have a b18b with gsr piston n rods, can i switch it with ls rods?
Reply 0
May 12, 2004 | 07:14 PM
Re: b18b rod on a gsr crank? (TspEk9)
Are you asking if you can use LS rods in your LS with GSR pistons?
Reply 0
May 12, 2004 | 11:18 PM
LS rod on gSr crank
Reply 0
May 14, 2004 | 02:39 AM
Re: (TspEk9)
They are not a direct swap.The GSR rods are thinner at the crank end.You would have to narrow the LS rods and use the GSR bearings.The next thing is the LS rods are shorter so the pistons would be way down in the cylinder and would need a custom piston to correct this.
Glenn
Reply 0
Subscribe
