B18a1 Rebuild... Can i run this setup?
Old Nov 27, 2007 | 09:56 AM
HondaKid936's Avatar
Default B18a1 Rebuild... Can i run this setup?
so i spun a bearing on the stock ls bottom i was running vtec and no oil was gettin by but yeah i wanted to know if i can run this setup bearings are going to be replaced by acl bearings (do i have to get bearings to specificaly fit the b16 crank or ls will fit?)
B16a jdm Crank on Gsr Pistons and rods on the B18a1 ?
is machine work required? or it will go
my friends letting me get em from him sorry ima noob at internal work
Old Nov 27, 2007 | 10:50 AM
Default Re: B18a1 Rebuild... Can i run this setup? (HondaKid936)
anyone?
Old Nov 27, 2007 | 11:55 AM
all-mtr-teg's Avatar
Use this site and plug in what you just said, see what your compression is and you decide if you would run that setup.
http://www.clubcivicquebec.com...f.php
Old Nov 27, 2007 | 02:13 PM
Default Re: B18a1 Rebuild... Can i run this setup? (all-mtr-teg)
thanks homie nice site never knew bout it, but im not good at reading compression looks
pretty low? Static Comp Ratio 6.63 : 1?
Old Nov 27, 2007 | 02:30 PM
racebucket_eg's Avatar
It would technically work but you would be de-stroking the b18a. Buy a new block IMO, it doesn't sound like you are ready to jump into engine building.
Old Nov 28, 2007 | 09:07 AM
Default Re: B18a1 Rebuild... Can i run this setup? (racebucket_eg)
yeah but ya gotta start somewhere thnkz n e ways peace
Old Nov 28, 2007 | 09:09 AM
King V's Avatar
A b16 crank has wider bearing surfaces than a B18 on the rod journals.
Old Nov 28, 2007 | 09:18 AM
mmuller's Avatar
Mad Scientist
Default Re: B18a1 Rebuild... Can i run this setup? (King V)
its not going to work... keep rods and cranks matched.
and ALL B series rod/ crank journals are the same size besides rod with on p72 and p73
Old Nov 28, 2007 | 09:44 AM
King V's Avatar
Default Re: B18a1 Rebuild... Can i run this setup? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
and ALL B series rod/ crank journals are the same size besides rod with on p72 and p73</TD></TR></TABLE>
B16, B18a/b, B20B= .937 inches
B18C=.857 inches
I stand corrected.
Old Nov 28, 2007 | 09:58 PM
thanks 4 the info i think im jus going to get another ls crank, someone on here told me a once a oem crank is turned its never the same its bad karma? is it true?
Old Nov 29, 2007 | 08:31 AM
King V's Avatar
Unless the machine shop is super reputable or has millions of $$$ tied up in machines, I wouldn't. Would you want your crank to take a **** because someone ground down a journal too much or machined it out of round on accident? Not me.
chrisc543
Sep 29, 2015 03:24 PM
95coupeb
26
Apr 28, 2010 07:00 AM
nytosc
10
Apr 7, 2009 05:48 PM
loudassVTEC
Jun 30, 2006 03:45 AM
