b18a/b vs b18c headers... what's the difference?
If I am just doing a swap in a Civic, for example, could I use an LS header instead of a GSR header? I can just get the exhaust fabbed from the header back, but is there a difference in the bolt pattern? Will the LS header not clear the B18C's oil pan?
b18b header is longer than the 94-99 b18c1 header because the b18c1 catback is longer . Where it bolts to the head is the same . Only difference is length which can easily be fixed
thanks guys
it'll be cheaper to buy an LS header for a budget side project buildup for a car i'm going to run in autox.
