B17a cams vs. B18c1 cams...
Old Aug 8, 2003 | 08:27 PM
maxim's Avatar
Default B17a cams vs. B18c1 cams...
Ok, I just bought some GSR cams last night from a guy with a 95 GSR. He said the cams came straight out of his car. I looked at these two pics to make sure I could identify the cam. I went ahead and bought them since they were very cheap. I would prefer to have the B18C cams(though I am not sure if there is a difference) over the B17a cams. Here are the widely used(on this site) pics I went by:
Here are the ones I bought:
Ok, I know it looks obvious that they are the B17a from comparing those pics. But, I found this link this morning on H-T about this guys cams he pulled out of his 98 GSR:
https://honda-tech.com/zerothread?id=436824
There were a few other threads that indicated that 94+ cams looked like the ones I bought. Though, I am still not 100% if these cams are B18C1 or B17a cams. Can anybody clearly define the two cams.
Also, is there any difference at all as far as the specs of these to cams besides the markings? I have seen one site post the specs of the 1st gen B16a, B18C1, and B17a as having the EXACT same specs. That doesn't sound right to me because I have also thought the 1st gen B16 cams to be the weakest in cam profile.
Thanks
Old Aug 9, 2003 | 04:13 AM
Hondasaurs's Avatar
I beleive the B17A cams are the same as the B16A cams. They both use the PR3 head. The B18C1 cams should be different considering the B18C1 uses the P72 head.
Old Aug 9, 2003 | 06:34 PM
AzG35's Avatar
Default Re: (Hondasaurs)
Yes, those are 96+ GSR cams. I pulled a few sets out of GSR heads and they were identical. Measure the lobes and compare them to GSR specs if you are still weary.
Old Aug 9, 2003 | 11:56 PM
maxim's Avatar
Default Re: (AzSi22)
ok, thanks guys. That's what I needed to know. I will measure them when I get a micrometer. Does anybody know the specs of the 94+ GSr cams? Lobe, etc..
Old Aug 10, 2003 | 10:23 AM
allmtr's Avatar
Default Re: (maxim)
b18c1 cams are much different than the 1st gen b16 and the b17 cams....
Old Aug 10, 2003 | 10:27 AM
allmtr's Avatar
Default Re: (maxim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxim &raquo;</TD></TR><TR><TD CLASS="quote">ok, thanks guys. That's what I needed to know. I will measure them when I get a micrometer. Does anybody know the specs of the 94+ GSr cams? Lobe, etc..</TD></TR></TABLE>
this page has b18c specs http://www.angelfire.com/az3/h....html
spoolinvtec54
Aug 21, 2011 03:24 PM
killacam661
Mar 13, 2010 10:57 AM
90teg
May 11, 2006 04:47 PM
jDMJeRk
Feb 26, 2004 09:59 AM
maxim
Aug 9, 2003 04:21 AM
