b16b vs. gs-r
it's time for a swap for my hatchie, i'm between a gsr or b16b.
my reasoning behind the ctr is the ability to achieve 1.8l by the stroke while others still think it's a 1.6, plus it's a bit more rare.
the gs-r is a great motor, i just think it's a little too common on the road.
can anyone post their experiences/opinions on the two?
If you plan on building either motor, which I'm assuming because you're talking about throwing out the 1.6L crank, I would go with the B18C1. It's gonna be cheaper than the B16B and will leave you more cash to mod it.
thats what i mean, take it to 1.8 by the crank, therefore having a 1.8 badged as a 1.6.
btw: what is ops/sds?
i have to disagree w/ you on the b16b crank issue, guy i know did the same mod and it ran-in fact it ran 12.1 on the motor. i'm confident this can be done.
The B16 has a shorter deck height. Therefore, you cant use the B18C crank or rods in it. I would get the GSR motor since its going to be much cheaper, and with the money you save, buy some JUN cams and high compression pistons
[Modified by Katman, 1:32 AM 5/6/2002]
that's my understanding.
i just got word on a '96 gs-r locally for $2000., everything but axles,ecu,harness.
should i jump?
should i jump?
I would..that's a pretty good damn price. Make sure it's legit though. You can reuse your civic harness if you plan on upgrading to a Skunk2 manifold along with reprograming your ecu. Axles you can find somewhere else...
Get whatever you want, but stroking a 1.6 to a 1.8 would be going from a near perfect R/S ratio to something a bit worse. The B16 will be grrrreat to rev. What about boring out a B16 to 1.8 instead?
...uhh if you're referring to a B16B's deck height, you're wrong. B16B uses a P72/B18C block casing which means equal deck height.
JDM B16B 98 spec.R
Water-cooled 4 stroke
Inline 4 cylinder, transverse
263 mm (10.354") < block height
81.0 x 77.4 mm (3.19 x 3.05 in)
1596 cc (97.3 cid)
10.8
Belt driven, DOHC w/VTEC, 16 valves
185 ps @ 8200 rpm
16.3 kgm @ 7500 rpm
115.6 ps/liter
33.0 mm/28 mm
18
45
243
45
10
235
28
11.5 (.453")
10.5 (.413")
Dual/Dual
USA B18C
270 mm (10.630") < block height
81.0 x 87.2 mm (3.19 x 3.43 in)
1797 cc (109.6 cid)
10.0
170 hp @ 7600 rpm
128 lbs-ft @ 6200 rpm
94.4 hp/liter
USA B18C
33.0 mm/28 mm
10
40
230
40
17
10.6 (.417")
9.4 (.370")
Dual/Single
I am with the earlier post, having the B16B you are at a revving advantage over
the B18C1. Undersquare engines make less TQ than square or over square engines. Most Hondas are undersquare, the K20C is perfectly square at 86 x 86 for example and makes GOOD TORQUE. If torque is what you want, build a B16B sleeve it and put balanced, forged 84.5mm pistons and stock sized forged rods in it
and spin till your heart is content! The rod to stroke ratio is superior in the B16B
over the B18C1 < this is the motor I have.
My $.02
1596 cc (97.3 cid)
10.8
185 ps @ 8200 rpm
16.3 kgm @ 7500 rpm
115.6 ps/liter
33.0 mm/28 mm
18
45
243
45
10
235
28
11.5 (.453")
10.5 (.413")
Dual/Dual
USA B18C
1797 cc (109.6 cid)
10.0
170 hp @ 7600 rpm
94.4 hp/liter
USA B18C
33.0 mm/28 mm
10
40
230
40
17
10.6 (.417")
9.4 (.370")
Dual/Single
My $.02
You could bore a b16 to 84.5, and have a 1.8l, or you could bore a B18C to 84.5mm and have a 2.0l. Yes, the 1.6 has a slightly better r/s ratio, but its not like a B18C wont rev to 9k. It would cost the same to bore either, so why not build a bored 1.8 and have way more torque/hp than a bored 1.6?
The deck height on that b16b is wrong.
Its the same as a B18C.
B18C1,B18C5, B18C6, B18C7,B18C4, B18C , they all say B18C hence they are all the same block.
Doesnt matter if its US ITR, JDM ITR, JDM GSR, Euro ITR, WHATEVER.
Same thing.
Same thing.
granada_sun
10
Jun 20, 2003 11:18 PM
