B16a1 VS. B16a2 ?'s please help
does anyone know if sensors from a b16a1(1st gen b16) will work with a 1994-1995 B18c1 engine wiring harness?
also while I am here if anyone has these sensors from a 1994-1995 b18c1 please let me know I am interested
Knock sensor
Vtec pressure switch
Vtec solenoid
btw, these are the sensors I am wondering would work from a b16a1
the reason I am asking this, is because I need these sensors and if they will work from a b16a1 I will just pick up an entire block to have the spare engine, if not, I am going to try to find just the sensors, anyway please let me know if you can answer the question for me or help me out with getting some sensors...thanks
Knock sensor
Vtec solenoid
the v tec soleniod will swap but the connectors are different, i assume that the oil switch is the same, and the knock sensors look the same and dont think that they would change thread pitch on it. so for all intents and purposes, the solenoid will work with a different connector and the rest i am not 100% sure.
cranker
Jan 10, 2011 05:28 PM
Freeltec
Jul 23, 2003 05:38 PM
