b16a OEM clutch...Setup turbo
I ran a stock clutch in my ls turbo with around 250 whp. Had a lot of slipping. I upgraded my clutch shortly after. I would recommend upgrading your clutch.
thanks for comments.
I see this exedy clutch on ebay.
I is the same off the OEM, or can support my setup?
http://cgi.ebay.com/ebaymotors/EXEDY...Q5fAccessories
personally i have never used the oem style street disc clutches, i dont know what they can support. when i upgraded my clutch i used just a ACT 6 puck sprung disc clutch which i liked with my 250 whp setup.
If you want to retain stock-like drivability while increasing the holding power of your clutch, get something with a kevlar disc. Otherwise, 6-puck clutches are perfectly streetable with the right pressure plate once you get used to them.
