B16A Ignition problems
Old Jul 23, 2013 | 03:37 PM
96 LS Turbo's Avatar
Default B16A Ignition problems
What is something that I can do to fix the ignition problems that I am having. I have changed the ignition coil, soon to change the crank sensor and well I don't know what else to chase down. I just got new injector seals for it as well so I don't know what to go after next does anyone know?
Old Jul 24, 2013 | 05:12 AM
kyden's Avatar
Default Re: B16A Ignition problems
you can't just say ignition problems and not actually explain what is happening.
Old Jul 24, 2013 | 08:29 PM
My friend Pao says that it was the ground or the fuse but I checked all of that and I still haven't found it. We now think that it is the ECU and I am going to replace that this weekend when I get the new one. Also the problems that I am having with it is that it will turn over but it will not fire, and there is no spark at all, I have a new crank sensor now and I don't think I need to change it I have changed the ignition coil and I have done everything that I can to get it to run but it decides that it doesn't want to run for me. If you have any ideas what is wrong with it please let me know thanks
$92CB7$
Jul 13, 2015 01:22 PM
JDM89accord_A20
Oct 22, 2009 05:11 PM
TheHatchHog
Aug 9, 2003 07:04 AM
