b16a axles
Old Nov 23, 2001 | 11:58 AM
89sir-9's Avatar
New User
Default b16a axles
what are the best axles to use for a b16a (first gen) swap into a 89 civic si. oh with the s1 transmission. would 86-89 axles work
Old Nov 23, 2001 | 03:19 PM
EightOhOne's Avatar
Default Re: b16a axles (89sir-9)
use 90-93 axles for the s1 tranny
read this link http://www.hasport.com/B16axles.htm
Old Nov 23, 2001 | 08:20 PM
rainforest's Avatar
Default Re: b16a axles (EightOhOne)
90-93 integra axles with the 86-87 ends is the best fit but the integras by there self will work.
Old Nov 23, 2001 | 08:29 PM
Mr.FBR's Avatar
Default Re: b16a axles (rainforest)
Not on the driverside...It depends on what intermediate shaft...You probably shoud stick with 86-89 teg axle on that side...
Pass side use the longer inner cup from a 86-89 teg and the shaft and outer from a 90-93.
Or go to http://www.raxles.com... they make the correct axles with all NEW parts not remans...and they are about the same as if you were to buy them from a parts store...less actually if you count building them yourself from 4 axles...
[Modified by Mr.FBR, 5:29 AM 11/24/2001]
bambam
Aug 24, 2017 12:27 PM
tmihok
Aug 7, 2004 03:34 PM
4inspeed
Jan 20, 2004 03:35 AM
Coricivic
May 21, 2003 08:29 PM
si foo
May 12, 2002 02:14 PM
