B16 TPS problem code 7 obd0 wiring checks out new TPS
Old Nov 13, 2014 | 01:02 PM
hfraziers's Avatar
Default B16 TPS problem code 7 obd0 wiring checks out new TPS
New TPS. Greenwire ground checks out. Yellow wire gets 4.6 - 4.9 V. Red wire has continuity/0 Ω back to ECU. Red wire back probed reads 20-40 mV at closed throttle, ~.35 V at wide open. There was no issue pre-swap (drove donor car home, TPS was fine.
Same red wire readings with old TPS.
Anyone know anything to suggest?
Old Nov 13, 2014 | 05:51 PM
holmesnmanny's Avatar
You want .45v-.50v closed throttle so calibrate it
Old Nov 14, 2014 | 01:29 AM
hfraziers's Avatar
Default Re: B16 TPS problem code 7 obd0 wiring checks out new TPS
I'm aware. If it wasn't clear, my above readings are maximum values.
Old Nov 14, 2014 | 02:44 AM
HondaPartsHero's Avatar
Technical Hero
List your year, make, model and ECU.
Old Nov 14, 2014 | 05:41 AM
hfraziers's Avatar
I think pw0, obd0, & b16 is pretty much all you need to know. All else seems extraneous
Old Nov 15, 2014 | 06:44 AM
Technical Hero
First off it's the rules of the forum to list all pertinent information including year, make and model at least. Secondly it is important because different models even within the same year range can have varying wiring colors and configurations.
fear45
Jan 8, 2019 12:26 PM
ej6.sean
11
Oct 7, 2009 06:01 PM
Mr_ET
Jul 3, 2008 04:02 AM
*Boostwerks*
11
Feb 24, 2005 10:45 AM
doublejz
May 13, 2004 01:46 PM
