B16- NGK BKR7E or BKR6E plugs?
I'm using the BKR7E-11 in my B16A, but I read where many people are using the 6Es. Are the 7Es colder? What do you guys suggest? Which one would be the best for my engine? Thanks.
im running bkr7e-11... i have a high compression engine... it depends on your mods... i have a hard time finding the bkr7e-11's other than sparkplugs.com, where do you get them?
My B16 is stock...no internal mods. And I haven't had the compression checked yet. What's the compression on yours? I got the plugs at a local shop http://www.groundzeromotorsports.com
I found this on the NGK site:
This makes me thinks that the 7E is too cold for a NA engine. Agree???
Let's make this really simple: when you need your engine to run a little cooler, run a colder plug. When you need your engine to run a little hotter, run a hotter spark plug. However, NGK strongly cautions people that going to a hotter spark plug can sometimes mask a serious symptom of another problem that can lead to engine damage. Be very careful with heat ranges. Seek professional guidance if you are unsure.
With modified engines (those engines that have increased their compression) more heat is a by-product of the added power that normally comes with increased compression. In short, select one heat range colder for every 75-100 hp you add, or when you significantly raise compression. Also remember to retard the timing a little and to increase fuel enrichment and octane. These tips are critical when adding forced induction (turbos, superchargers or nitrous kits), and failure to address ALL of these areas will virtually guarantee engine damage.
An engine that has poor oil control can sometimes mask the symptom temporarily by running a slightly hotter spark plug. While this is a "Band-Aid" approach, it is one of the only examples of when and why one would select a hotter spark plug.
depends on compression the more compression ther is the more heat is generated by the squeezing of the air... im running somethin like a 12.2 :1 compression...
