B16 cams VS B18c
JDM B16 2-3 gen is a 240 45/15 intake cam LiKe TypeR y0 according to Gspeed/powered by honda page (old school) the first gen is a 230 40/10 cam, same as the 92-93, 94-02 GSR intake cam so I would assume the USDM spec is also the same for USDM B16a2, considering most guys purchase a ITR/CTR intake cam to mimick the 2-3gen JDM B16a:
http://www.g-speed.com/pbh/b16a/
< backing up my previous comment
the kid with the GsR y0
question... why do you need to know the difference for very little if any difference between the cam aforementioned...
curiousity? IF you intend to use one or the other, get an ITR or CTR and you'll see a difference for sure...
[Modified by MikeSarr_GSR, 6:23 AM 2/25/2003]
curiousity? IF you intend to use one or the other, get an ITR or CTR and you'll see a difference for sure...[Modified by MikeSarr_GSR, 6:23 AM 2/25/2003]
the reason why I ask is cause I let my "friend" borrow my GS-R cams for his b16 when I got my crower cams and I am getting them back now and I wanted to make sure that they were my cams not his b16 cams 'cause I am pretty sure that they are differnt at least from the older b16 cams. thanks for the help, although if anyone has pictures comparing the two that would help as well (I emailed katman, hasnt responded)
Sorry everybody but I just thought about this... to MikeSarr_GSR man you gotta get your old avatar back... that VTEC valvecover was bad ***.. Too bad we all lost our **** when H-T was doing whatever they were doing... Oh well... Peace
That chart may SAY they're the same, but guys have dyno proven that they're NOT. I have 1st gen b16's in my car now and have some later model GSR's going in soon, I'm going measure the lobes and see for myself if there's a difference.
yes there is a way.
You can peep my B-series DOHC VTEC cam ID page here:
http://www.ff-squad.com/VtecCams.htm
although it's due for an update.
Same cams, different motor, the b16 and b18c do not have the same rocker arm ratio! That means the same cam will have different lift at valve depending on which rocker arm is used.
So people that are swapping their B16 cams out for GSR's and NOT changing the Rocker arms really AREN'T getting gains?
I'm not arguing, but I've heard/seen people gain power by swapping between these 2 cams
I will get the R/A ratio's for both today and post em.
holy jees man, the spec is the same. anyone can dyno prove something... if we are talking 2-3whp c'mon. the 2-3gen JDM B16 has a intake cam with the same valve closing/opening specs as ITR. that and .2 cr was good for 10 more hp in stock trim. look at the spec. why not just get an intake cam from an ITR or CTR and really gain something solid? I dont understand what you think you will gain by researching these cams further outside of the knowledge you would gain from mic-ing every lobe honda ever made...
Ya, no need to argue. Im pretty sure they are the same cams. Also, GSR cams would be in demand for B16 owners if they were different. Try selling some GSR cams. You'll sit on them. But back to the original topic of you telling them apart visually, I dont see how you could unless they have different numbers/letters marked on them. The ITR 00+ ITR cams are a great upgrade for the b16 or GSR. I got about a 10 hp gain.
[Modified by GSRTUNR, 8:20 PM 2/26/2003]
People are swapping out B16 cams and making more horsepower with the GSR's- this is based on FI setups, btw. Go to the FI board and you'll see proof. If it were only going to net 2-3hp, I wouldn't bother. Also, the rocker arms ARE the same for GSR's, and the B16(2000 civic to be exact) so any gain realized has to be because of the cam.
B16 cams are made for a 1.6L motor and the GSR cams are made for a 1.8L. Obviously they did not use the same cam for these motors which are different
. Read katmans page once again. B16a cams are the weakest period. Note B18c is not in that statement.
if you can, try and see if you can look at both sets up close, check the vtec(middle) lobes, if a certain set seems taller or looks like it has more duration, thats your set.
I've measured both cams and they are NOT the same. Even by looking at the specs in the service manuals, the have different lobe heights. The exhaust are very similar, but the intake cams for the GSR have more duration and .2mm more lift.
there are different markings, but the specs posted here
are simliar if not the same. as far as my statement of the
2-3gen B16a being different, check the Intake profiles. they in turn
make 170 at the crank compared to the 160 of the B16a G1.
Duration spec is larger, LIFT is almost (10.6/10.7) the same.
My only point is that the cams between USDM B16, JDM B16a G1,
and B17/18C is negligable if any. If anyone is making power with
any combinbation of stock cams it doesnt suprise me, cams can
wear
wear
