b series transmission to engine block bolts
Old Oct 29, 2009 | 03:50 PM
AfTeRhOuRs209's Avatar
Default b series transmission to engine block bolts
alright so ive been to honda and acura and i have even talk to the honda distribution center. I need the part numbers for the transmission housing to engine block bolts that attach the tranny to the engine... im guessing all of the b series are probably the same considering they are all interchangeable but for sake of the post im using a b16a2 si tranny on a obd1 ls block. thanks a head of time... this is literally holding up the whole project.
ive been to autozone, kreagen etc etc.... they say to go to honda or acura directly.
Old Oct 29, 2009 | 03:53 PM
night's Avatar
Default Re: b series transmission to engine block bolts
yes, get honda bolts. they are called bellhousing bolts.
just find someone at the parts counter that isn't stupid.
Old Oct 29, 2009 | 06:00 PM
ok so go to honda and not acura and ask for bellhousing bolts, thanks a bunch!
Old Oct 29, 2009 | 07:40 PM
night's Avatar
honda/acura. whatever. just B series. about 3.5 or 4" long.
Old Oct 30, 2009 | 04:31 AM
kyden's Avatar
if you go to honda its #33. under ALTERNATOR BRACKET-ENGINE STIFFENER
90051-PE0-000 BOLT, FLANGE (12X70) 3 of those. one of the starter bolts also hold it on.
if you go to acura, its #24. System Name / Component : ENGINE WIRE HARNESS-CLAMP (2)
Old Oct 30, 2009 | 09:07 PM
thanks!
Old Apr 26, 2011 | 09:51 PM
tronic's Avatar
I've never been able to find these bolts until now!
They are also listed under
ENGINE WIRE HARNESS - CLAMP
about $20 for all 5
23 90050-PG7-000 BOLT, FLANGE (12X65) qty 2
24 90051-PE0-000 BOLT, FLANGE (12X70) qty 3
(parts lookup for 2001 ITR)
EJ8chu
Sep 15, 2006 11:49 PM
killerpenguin21
14
Jul 13, 2006 04:37 PM
275Performance
Jan 5, 2003 07:16 PM
