B series oil pumps!!?! help
Old Mar 9, 2009 | 11:03 PM
dc4-b20's Avatar
Default B series oil pumps!!?! help
Does anyone have a link or maybe know some info on B series oil pumps and if their diffrent???
I cant find any info on B series oil pumps anywhere......
i need to know if theres a difference in the VTEC and non VTEC pumps
Old Mar 9, 2009 | 11:13 PM
92cxturbo's Avatar
Default Re: B series oil pumps!!?! help
the part number is the same for the b20 and the obd2 gsr/typer so those are the same. but Im sure others are not
Old Mar 9, 2009 | 11:57 PM
dc4-b20's Avatar
i think part numbers can be the same for diffrent items example when you buy spark plugs thers difrences in the but example for the b16 motor theres 2 diff cars
94-95 del sol
99-00 civic si and the part numbers are the same but i believe that the spark plugs can/are diffrent ??
what im trying to say is (and im not 100% sure on this) but i think part numbers are specifically for what cars they fit?
Old Mar 10, 2009 | 12:20 AM
dc4-b20's Avatar
Ok well long time searching and i have finally found out the big secret to the oil pumps. The only thing thats different in them is indeed just a washer.
BUT that washer is the thing that changes oil pressure because takin tht out allows the hexbolt plug to sit lower and compress the relief spring a little more.this causes higher oil pressure before the plunger is lifted off the seat to bypass the oil
so diffrences are infact oil pressure because of that little washer :thumb:
Old Mar 10, 2009 | 04:34 AM
kyden's Avatar
96-01 b series all have the same pump, everything internally is the same. 94-95 have different ones between gsr/ls.
Pompiuses
30
Sep 18, 2010 02:56 PM
Pagley
Mar 10, 2010 03:40 PM
hondahead21
Mar 4, 2009 09:33 AM
h224thgensedan
Feb 19, 2009 11:03 AM
EG8R
Dec 5, 2003 07:47 PM
