B-Series Block Build-up (How To Article):
Old Sep 22, 2004 | 05:35 PM
  #26
seek167's Avatar
Default Re: B-Series Block Build-up (erics99si)
great write up. this should be a sticky
Old Sep 22, 2004 | 08:17 PM
  #27
G U E C O's Avatar
Default Re: B-Series Block Build-up (seek167)
Old Sep 22, 2004 | 08:46 PM
  #28
_noname_'s Avatar
Default Re: B-Series Block Build-up (stock93cx)
i like it, i love it. i want some more of it!!!!
Old Sep 24, 2004 | 11:41 AM
  #29
R-Toyz.com's Avatar
How long did it take you to do the build?
A mechanic of mine estimated around 10-15 hours of work (based on dealership labor rate). I believe it will take less, and most of the time being consumed by the plastigauging.
Great build btw.
Old Sep 26, 2004 | 07:47 AM
  #30
eRACING's Avatar
Default Re: (rtzcom)
plastigauging does take about a hour and some to do just because its a repeative process of torquing bolts down, taking it all apart again then bolting it back down again, etc.. I'd say if you have all the neccessary parts and tools sitting right with you at the time of the build, you could finish the block only in 5-6 hrs if not quickers... I've done a few blocks so it doesn't take me too long to put one together if the motors already outta the car of course...
I actually have a race only block that I should have complete by early December that'll be pretty sick to look at... That one will be a even higher compression bigger displacement motor though I won't be doing a write up on that one... will show pictures though for drooling purposes only..haha
Old Sep 26, 2004 | 10:00 AM
  #31
BIGDADDY-R's Avatar
Default Re: (erics99si)
dude i dont want to sound cocky cause i am not!!but who in the hell uses plastigauge to build a motor!! invest in some mics,calipers and a dial bore gauge and do it right. i would never post pics of myself building a motor and using plastigauge for measurements. that was good for the 70's and 80's.
Old Sep 26, 2004 | 02:11 PM
  #32
XzzYzzX's Avatar
Default Re: (Manuel)
Great Write Up..Lots of good info...
Old Sep 28, 2004 | 08:56 PM
  #33
AsianMullet's Avatar
Default Re: (XzzYzzX)
yup nice write up
Old Oct 6, 2004 | 01:10 PM
  #34
BLUE EH3's Avatar
Help we my pennies
Default Re: B-Series Block Build-up (JDMDA9)
nice WU
Old Feb 21, 2005 | 11:08 PM
  #35
91TegLS's Avatar
Default Re: B-Series Block Build-up (HONDA_TYPE_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA_TYPE_R &raquo;</TD></TR><TR><TD CLASS="quote">Excellent article. I was yearning for more pics, but that's because I learn by seeing. So few know the importance of plastigage. I hope this gets archived so I can find it when I finally decide to undertake a block buildup. Thanks for the info! </TD></TR></TABLE>
Have you seen this one yet?
http://www.boosted-hybrid.com/...?t=326
I definitely learned alot from this thread as well as the one I'm linking you to.
Old Mar 5, 2005 | 06:34 PM
  #36
ttracing03's Avatar
Default Re: B-Series Block Build-up (How To Article): (erics99si)
great article..Thanks
Old Mar 6, 2005 | 09:40 AM
  #37
f@sth@tch89's Avatar
Default Re: B-Series Block Build-up (ttracing03)
this write up is a Godsend for us beginners wanting to build our own engine in our garage, basement, shop, etc....
Old Mar 6, 2005 | 04:40 PM
  #38
PrettyLude's Avatar
Default Re: B-Series Block Build-up (f@sth@tch89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f@sth@tch89 &raquo;</TD></TR><TR><TD CLASS="quote">this write up is a Godsend for us beginners wanting to build our own engine in our garage, basement, shop, etc....
Old Mar 10, 2005 | 10:11 AM
  #39
HONDA RR's Avatar
VERY GOOD EXPLANATION WITH DETAILED PICTURES.
Old Mar 11, 2005 | 10:43 AM
  #40
Quitripin's Avatar
Default Re: B-Series Block Build-up (MITSUBA)
Old May 15, 2005 | 08:58 PM
  #41
JDMSiGuy17's Avatar
Default Re: B-Series Block Build-up (Quitripin)
very nice write up!
Old Sep 6, 2005 | 09:11 PM
  #42
standinghollow's Avatar
Default Re: B-Series Block Build-up (JDMSiGuy17)
awsone write up i could use this
Old Sep 6, 2005 | 11:22 PM
  #43
mrDFWmechanic's Avatar
very informative good write up this should be kept at the top of this section
Old Sep 13, 2005 | 06:59 PM
  #44
civicsi99msr's Avatar
Default Re: B-Series Block Build-up (How To Article): (eRACING)
would like to know if you would post the toque specs for rod/mains and head bolts for a b16 plz..
Old Sep 14, 2005 | 08:12 AM
  #45
(puma)'s Avatar
very nice thread, decided to push this one to the top for myself and others, because i've been looking for this thread for sometime now. i really think that this thread should become a sticky.
Old Sep 14, 2005 | 02:59 PM
  #46
ThE PiMpiN Co's Avatar
Default Re: B-Series Block Build-up (B_Series)
cool, good write up.......um........can you do it again, but this time for an H-series?
Old Sep 20, 2005 | 07:47 PM
  #47
mportbusta's Avatar
Default Re: (bign2odaddy)
I know a lot of builders use plastigauge. If u dont have the funds for tools, plastigauge works man....
Old May 1, 2012 | 04:53 PM
  #48
206dagsr's Avatar
Originally Posted by Kendall
One of the most informative write-ups I've read in recent memory.
Hey My Motor Not Going OVer 5 thousand rpm Any One Can Help me Out
Old May 1, 2012 | 04:54 PM
  #49
206dagsr's Avatar
My b18c1 not passing 5thousand rpm any one can help me out??
Old May 1, 2012 | 04:58 PM
  #50
EJ6Shwag's Avatar
this is pretty nice, will be sure to use it when i swap my motor
