B-20A6 crank inside A B-18A1?
Old Sep 25, 2003 | 05:05 PM
RonRon's Avatar
Default B-20A6 crank inside A B-18A1?
Would this be possible,and what good would come out of it.
Old Sep 25, 2003 | 07:18 PM
untitled's Avatar
Default Re: B-20A6 crank inside A B-18A1? (family sedan)
its the same crank.
Old Sep 25, 2003 | 09:22 PM
Kaspin's Avatar
If it's the Prelude B20A (and I assume you mean B20A5 not 6, there was a 6 in europe, but the 5 is what's here in the states), then they are not the same.
The Prelude has a 95mm stroke. The Big end bore of the rods is the same, as are the crank journals. I don't know if it'll fit for sure, you might have a problem with the timing gear and pulley being too close to the block
hu
Jan 29, 2006 11:24 PM
egcivic123
Jan 15, 2005 11:46 AM
Curturbo
Dec 28, 2004 08:45 PM
flat-blk-HB
Jan 13, 2004 07:26 PM
