Axle coming loose????
Old Sep 24, 2003 | 03:31 PM
nolimits's Avatar
Default Axle coming loose????
I swapped a B18C-r into a 00 Civic SI using the SI's axels. Occationally the passenger side axle pulls out of the transmission by an inch or so resulting in a small trans leak (which is how I discovered it) The first time I thought it was a fluke and just pushed it back in...now it's happened twice (in ~500miles). I never had this problem when the B16a2 was in with the same axles. What am I missing?
Old Sep 25, 2003 | 04:17 AM
JimBlake's Avatar
Default Re: Axle coming loose???? (nolimits)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nolimits &raquo;</TD></TR><TR><TD CLASS="quote">... What am I missing?</TD></TR></TABLE>Maybe you didn't get the axles in far enough to snap into place?
Old Sep 25, 2003 | 04:23 AM
nolimits's Avatar
Default Re: Axle coming loose???? (JimBlake)
I get it far enough to feel like an indent...but it doesn't snap firmly. I'll have to see if I can coax it in further.
Old Sep 25, 2003 | 05:19 AM
bruthaboost's Avatar
The cv joint should be right up against the tranny seal. I've had the same prob. Make sure you don't drive without the tranny oil should it pop out again. You'll burn up those bearings.
Old Sep 25, 2003 | 05:58 AM
pro1342's Avatar
You should try replacing the snap ring on the end of the axle.....
Old Sep 25, 2003 | 05:50 PM
nolimits's Avatar
Default Re: Axle coming loose???? (pro1342)
Once I push them in they seem to be pretty firm. I think they're only popping out after some hard driving (the first time I noticed shortly after a 1/4mi track day and the other was after a big burnout leaving a car show!!)
bmxkills
Jan 30, 2011 08:53 PM
BONGFIRE420
24
Oct 6, 2007 12:10 PM
nonvteclude
Aug 7, 2006 08:45 PM
ramtyper19
Nov 10, 2005 06:19 PM
14bcoupe
Jul 25, 2005 05:24 PM
