autometer voltage reads
Old Oct 21, 2004 | 02:37 PM
SpoonIntegra808
Guest
Posts: n/a
Default autometer voltage reads
my volts read just below 12, is this normal or is there something wrong? What could be the lost of volts if this is a problem?
Alternator? Batttery?
What autoshop could I go to check out my problems? I have a 96 Civic Hatch Back B16A1 Motor!!!!!!!! PLease help me!!!!!!!!!
Old Oct 21, 2004 | 06:27 PM
Fobtions's Avatar
Default Re: autometer voltage reads (SpoonIntegra808)
is this reading , when the car is on.?
when the car is on it should be above 12
Old Oct 21, 2004 | 07:47 PM
drdisco69's Avatar
Default Re: autometer voltage reads (Fobtions)
Good battery is around 12.5v off, and 13.5v - 14.5v running. A load test will tell you more.
Old Oct 21, 2004 | 09:39 PM
PrettyLude's Avatar
here's a way to check ur alternator, pull off your negative terminal while the car is running, if it dies, then ur alternator is bad
yadada
Nov 16, 2008 03:27 PM
yadada
Jul 1, 2008 01:29 PM
EG6R
May 10, 2007 01:57 PM
ge_itr
Aug 19, 2006 01:40 PM
SilverDc2
Audio / Security / Video
28
Jun 16, 2003 07:55 PM
