ARP rod bolt question
The B series bolts are all 11mm and D series are 10mm and Prelude/Accord are 12mm. If you are going to use ARP's make sure you use the Bseries and for LS/VTEC you have to GSR bolts or studs.
Two avaible ARP rod bolt sets for Honda B series:
ARP-208-6001 Honda 1.2L-1.6L 8mm
ARP-208-6401 Acura 1.8L 9mm
My question is will the 8mm holp up on LS rods...
For b18a rods the 8mm ones are what you need. That's what I used. On the b18b's I've heard you use the 9mm ones but I'm not sure on that since I've never built a b18b bottom end. Can someone confirm or deny this?
